你好,
到目前为止我所做的是...... 0.控制300W 24V轮毂电机......(带STM32F407VE) 1.电机参数通过Motor Profiler获取 2.霍尔传感器设置为主传感器。 Observer + PLL是辅助传感器 3.可以通过Workbench和API在程序中控制速度,扭矩。 问题是...... 答:这是电动滑板车。启动时,看起来像低扭矩。 它试图转向。但失败了。没有负载,没关系。 我该如何在程序中处理它?重负荷启动。 B.当MCI_StartMotor()执行时,电机在转动之前突然拉扯。 这就像突然施加大电流一样。 如何在程序中顺利启动? C.编号2.如果Observer + PLL是主传感器,则每次启动失败。 但霍尔传感器是主要的。好像没问题。我仍然不明白为什么。 先谢谢你。 以上来自于谷歌翻译 以下为原文 Hello, What I have done so far is ... 0. In controlling of 300W 24V In-Wheel motor ... (with STM32F407VE) 1. Motor parameters were taken through Motor Profiler 2. Hall sensor is set to main sensor. And Observer+PLL is aux sensor 3. Can control speed, torque through Workbench and API in program. Problem is ... A. This is electric scooter. When start up, seems like low torque. It try to turn. But fail. Without load, it is ok. How can I handle it in the program? Starting up with heavy load. B. When MCI_StartMotor( ) execute, motor suddenly tug before turning. It is like big current is applied suddenly. How can I start up smoothly in the program ? C. in number 2. if Observer+PLL is main sensor, everytime start-up failure. But Hall sensor is main. It seems ok. I still don't get it why. Thank you in advance. |
1个回答
再见
A. FW尝试提供您在电机额定电流中设置的最大电流(如果HW允许) B.在速度模式下,FW尝试达到目标速度,如果速度控制器可以产生在电机额定电流中设置的最大电流以达到目标。在这种情况下,选项可以使用几秒钟的速度斜坡以避免拖船。在速度模式下,电流由用户设置。在WB中,您无法发送当前斜坡,因此您必须逐渐增加电流。或者通过程序,您可以使用API ExecuteTorqueRamp。您可以在工作台文档的链接中找到MC API的说明。 C.可能系统没有很好地调整。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao A. The FW tries to deliver the maximum current that you set in the Motor Nominal Current (if the HW allows it) B. In speed mode the FW tries to reach the target speed and if the speed controller can generate the maximum current set in the Motor Nominal Current to reach the target. In this case an option can be use a speed ramp of some seconds to avoid tugs. In speed mode the current is set by the user. In WB you can't sent current ramps and so you have to gradually increase the current. Or by program you can use the API ExecuteTorqueRamp. You can find the description of the MC API in the link in the documentation of the workbench. C. Probably the system is not well tuned. Ciao Gigi |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1392 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
486浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
552浏览 3评论
466浏览 3评论
GMT+8, 2024-4-19 09:37 , Processed in 0.890737 second(s), Total 69, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
