首先,开发板使用的是STM32l073rz-nucleo。stm32l073支持4个usart串口,1个lpsuart。当前项目需要使用4个串口。我选择了usart1、2、4、5.前三个已经能够正常的共同使用。但是usart5在使用过程中,没有任何反应。单步跟踪时,usart5的发送过程能顺利过去,但是串口助手没有任何输出。请教,这是为何呢? 配置代码如下: stm32l0xx_it.c void USART1_IRQHandler(void) { HAL_UART_IRQHandler(&huart1); } /* USART2的中断处理函数 */ void USART2_IRQHandler(void) { HAL_UART_IRQHandler(&huart2); } /* USART4的中断处理函数 */ void USART4_5_IRQHandler(void) { HAL_UART_IRQHandler(&huart4); } /* USART5的中断处理函数,这个中断处理函数是自己添加的,并且usart5的中断向量也是自行添加到.s文件中的。 */ void USART5_IRQHandler(void) { HAL_UART_IRQHandler(&huart5); } usart.c /* USART init function */ void MX_UART_Init(UART_HandleTypeDef* huart) { if (huart == &hlpuart1) { huart->Instance = LPUART1; huart->Init.BaudRate = 9600; } else if (huart == &huart1) { huart->Instance = USART1; huart->Init.BaudRate = 9600; } else if (huart == &huart2) { huart->Instance = USART2; huart->Init.BaudRate = 9600; } else if (huart == &huart4) { huart->Instance = USART4; huart->Init.BaudRate = 9600; } else if (huart == &huart5) { huart->Instance = USART5; huart->Init.BaudRate = 9600; } huart->Init.WordLength = UART_WORDLENGTH_8B; huart->Init.StopBits = UART_STOPBITS_1; huart->Init.Parity = UART_PARITY_NONE; huart->Init.Mode = UART_MODE_TX_RX; huart->Init.HwFlowCtl = UART_HWCONTROL_NONE; huart->Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE; huart->AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT; if (HAL_UART_Init(huart) != HAL_OK) { Error_Handler(); } } void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle) { GPIO_InitTypeDef GPIO_InitStruct; if(uartHandle->Instance==USART1) { /* Peripheral clock enable */ __HAL_RCC_USART1_CLK_ENABLE(); /**USART1 GPIO Configuration PA9 ------> USART2_TX PA10 ------> USART2_RX */ GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_USART1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* Peripheral interrupt init */ HAL_NVIC_SetPriority(USART1_IRQn, 0, 0); HAL_NVIC_EnableIRQ(USART1_IRQn); } else if(uartHandle->Instance==USART2) { /* Peripheral clock enable */ __HAL_RCC_USART2_CLK_ENABLE(); /**USART2 GPIO Configuration PA2 ------> USART2_TX PA3 ------> USART2_RX */ GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_USART2; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* Peripheral interrupt init */ HAL_NVIC_SetPriority(USART2_IRQn, 0, 0); HAL_NVIC_EnableIRQ(USART2_IRQn); } else if(uartHandle->Instance==USART4) { /* Peripheral clock enable */ __HAL_RCC_USART4_CLK_ENABLE(); /**USART4 GPIO Configuration PC10 ------> USART4_TX PC11 ------> USART4_RX */ GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_11; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF6_USART4; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); /* Peripheral interrupt init */ HAL_NVIC_SetPriority(USART4_5_IRQn, 0, 0); HAL_NVIC_EnableIRQ(USART4_5_IRQn); } else if(uartHandle->Instance==USART5) { /* Peripheral clock enable */ __HAL_RCC_USART5_CLK_ENABLE(); /**USART2 GPIO Configuration :RZ LQFP64 Pin55/56 PB3 ------> USART5_TX PB4 ------> USART5_RX :VZ LQFP100 Pin41/42 PE10 ------> USART5_TX PE11 ------> USART5_RX */ GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF6_USART5; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); /* Peripheral interrupt init */ HAL_NVIC_SetPriority(USART4_5_IRQn, 0, 0); HAL_NVIC_EnableIRQ(USART4_5_IRQn); } } main.c ... MX_UART_Init(&huart1); MX_UART_Init(&huart2); #ifdef DEF_USART4 MX_UART_Init(&huart4); #endif #ifdef DEF_USART5 MX_UART_Init(&huart5); #endif ... while (1) { // 虚拟串口用的usart2,重定向 printf("nloop!n"); /* Insert 5 seconds delay */ BSP_LED_On(LED2); HAL_Delay(1000); /* usart1中断发送 */ if(HAL_UART_Transmit_IT(&huart1, (uint8_t*)gcTx1Buffer, TX1BUFFERSIZE)!= HAL_OK) { Error_Handler(); } while (Uart1Ready != SET) { } Uart1Ready = RESET; HAL_Delay(500); /* Checks if Buffer full indication has been set */ BSP_LED_On(LED2); HAL_Delay(1000); #ifdef DEF_USART4 if(HAL_UART_Transmit(&huart4, (uint8_t*)gcTx4Buffer, TX4BUFFERSIZE, 1000)!= HAL_OK) { Error_Handler(); } HAL_Delay(500); #endif #ifdef DEF_USART5 if(HAL_UART_Transmit(&huart5, (uint8_t*)gcTx5Buffer, TX5BUFFERSIZE, 1000)!= HAL_OK) { Error_Handler(); } HAL_Delay(1000); #endif printf("nOff!n"); //BSP_LED_Init(LED2); //HAL_Delay(2000); //printf("nWake up.n"); HAL_Delay(1000); //DisplayClkInfo(); } .... 通过查看startup_stm32l073xx.s, 在原本保留字的位置上,增加了DCD USART5_IRQHandler,以及后文增加了:EXPORT USART5_IRQHandler [WEAK] 但是程序运行过程中,usart5应该输出的内容,从pb3、pb4连接到电脑后,串口助手没有响应。 通过关闭usart4,也没有变化。 现在我关注到usart4、5在定义中断IRQn时,定义为共用的USART4_5_IRQn(第27号)。因此,USART4的中断处理用了USART4_5_IRQn作为设置参数。而USART5_IRQHanfler也用了USART4_5_IRQn。 这里有没有矛盾? 为何不见usart5的输出,怎么解决? 谢谢指正。 |
7个回答
通过示波器抓取信号,usart5是有输出信号的。信号的长度和输出信息一样。但是内容好像不一致。
我设置了gcTxbuf[4]={0xA5,0xAA,0x55,0x85}; 根据示波器读的数据是,负电平:1010 1101 0011 0101 0100 1010 1010 1000,即AD 35 4A A8. 原因还不明。 |
自行添加中断函数到启动文件中,恐怕不行吧?
看样子是串口4 5共用一个中断向量,应该在串口4 5的中断函数中识别出来,分别处理
如果不另外定义中断函数。4和5进同一个中断,根据什么,如何区分huart呢? void USART4_5_IRQHandler(void) { HAL_UART_IRQHandler(&huart??); } |
用的是同一个中断向量,你如果定义2个中断函数,也就是2个中断入口地址,肯定是错的;
通过分别判断2个串口的标志位来判断到底是谁触发的中断; 这个我没试过,你可以尝试一下下面写法 void USART4_5_IRQHandler(void) { HAL_UART_IRQHandler(&huart4); HAL_UART_IRQHandler(&huart5); } |
增加的这一句“DCD USART5_IRQHandler”其实没有用的 , 这个启动文件中 指明了复位和各个中断的入口地址,和芯片的架构有关,芯片确定后,各个中断的入口地址也就确定了,和你文字的改动增加已经没有任何关系了,这些文字只是给写程序的人一些文字的提示,标识出了什么中断就执行什么地方的指令的文字含义。所以USART4 USART5,中断后只会执行 “跳转到 USART4_5_IRQHandler 处的指令”。你自己增加的指令只是你的一厢情愿,机器是不会理睬的。
串口4和5的发送应该不会有问题, 因为没有用到中断。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
745 浏览 2 评论
912 浏览 1 评论
1758 浏览 0 评论
【嵌入式SD NAND】基于FATFS/Littlefs文件系统的日志框架实现
671 浏览 0 评论
求助!STM32F4单片机编程与设计sEMG信号采集电路问题
868 浏览 0 评论
GMT+8, 2024-3-29 10:26 , Processed in 0.603718 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
