你好,
我正在为我的应用和PSoC Low电源模式工作,需要在深度睡眠模式下移动MCU以减少电流。 到目前为止,我用看门狗定时器(唤醒源)获得2秒的深度睡眠时间间隔。在这个项目中,需要超过2秒。 当我在深度睡眠中工作时,我知道看门狗定时器和WCO作为时钟源,它的频率是32.768千赫,如果我能把这个时钟降低到1千赫,比我能得到64秒的深度睡眠间隔,这对我的项目来说是绰绰有余的。 有人能指导我,如何减少看门狗计时器的时钟? 以上来自于百度翻译 以下为原文 Hello, I am working on PSoC Low power mode to my application & it is required to move MCU in deep sleep mode to reduce current. As of now, I am getting 2 sec of deep sleep interval with watchdog timer (wakeup source). And in the project, it is required to get more than 2 sec. While working on deep sleep I get to know that watchdog timer works with WCO as clock source which is 32.768 KHz, If I could reduce this clock to 1 KHz, Than I can get as much as 64 sec of deep sleep interval which is more than enough to my project. Can anybody guide me, How to reduce clock for watchdog timer ? |
1个回答
你好,
没有必要减少看门狗定时器的时钟,以增加深度睡眠间隔。为了增加深度睡眠时间间隔,你可以使用两个看门狗定时器,WDT0和WDT1通过级联。请参阅下面的代码,讲述如何级联两个定时器。WDT1将在匹配值上产生中断。 有关看门狗计时器的更多信息,请参考PSoC Creator中的代码示例“WestDokPoSoC4Load示例”。 谢谢, 心理医生。 以上来自于百度翻译 以下为原文 Hello, There will be no need to reduce the clock for watchdog timer for increasing the deep sleep interval. To increase the deep sleep time interval you can use two Watchdog timers which are WDT0 and WDT1 through cascading. Please see the code below which tells about how to cascade the two timers. WDT1 will generate interrupt on match value. For more information on Watchdog Timers please refer the code example "Watchdog_PSoC4_Example" in PSoC Creator. Thanks, PSYU. |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-23 21:44 , Processed in 0.801737 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
