我用CG3PA芯片设计手机充电器。输入将是一个大约5V的电机电源,预期输出也将是大约5V。我在数据表中设计了类似于图7的示意图,并且我遇到了以下问题:
1。如果我用16针代替24针好吗? 2。我应该如何连接FB引脚,如果我的输入是5V已经与分压器? 三。数据表提到,我需要一个编程硬件,但我不需要数据传输为我的目的,这对我来说是必要的吗?另外,如果需要的话,我应该如何连接SWDYDAT、SWDY-CLK和AxRes? 谢谢 以上来自于百度翻译 以下为原文 I am designing a mobile phone charger using CCG3PA chip. The input will be a motor power supplies about 5V and expected output would be about 5V too. I have designed the schematic similar to Figure 7 in the datasheet, and I have encountered the following questions: 1. Would it be fine if I use 16-pin instead of the 24 pins? 2. How should I connect FB pin if my input is 5V already with out the voltage divider? 3. The datasheet mentioned that I would need a programming hardware, but I do not need data transfer for my purpose, would this be necessary for me? Also, how should I connect SWD_DAT, SWD_CLK, and AXRES if I would need it? Thanks |
3个回答
我不明白,所以让我进一步澄清我的问题: 当你说“浮动”的FB引脚,你的意思是连接到地面或 输入电压? 至于编程引脚去,我不知道它是用来做什么。如果我 不要使用它们(直接研磨它们),芯片会工作吗?即供应 电源C型插座。 而且,我知道我用24针画了一张照片,但是我打算用16个。 引脚芯片。 谢谢 以上来自于百度翻译 以下为原文 I didn't understand that, so let me clarify my question further: when you said "float" the FB pin, did you mean connect it to ground or to input voltage? As far as the programming pins go, I am not sure what it's used for. If I don't use them (ground them directly), will the chip work? i.e. supplying power to the type-c receptacle. Also, I know I put up a picture with 24 pins, but I am intending to use 16 pins chip. Thanks |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1903 浏览 1 评论
1654 浏览 1 评论
3409 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1569 浏览 6 评论
1381 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
190浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
325浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-26 02:12 , Processed in 0.676922 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
