嗨,我收到错误:Hades Canyon NUC上的“当前硬件和/或驱动程序设置不支持OpenGL直接状态访问扩展”。
任何提示,技巧或变通方法? 我需要克服这个错误,所以我们的部门可以买很多NUCS。 以上来自于谷歌翻译 以下为原文 Hi, I'm getting the error: "OpenGL direct state access extension is not supported with current hardware and/or driver setup" on the Hades Canyon NUC. Any tips, tricks, or workarounds? I need to get past this error so our department can buy a lot of NUCS. |
5个回答
rubilacx:我们将尽最大努力为您提供帮助。为了提供最准确的响应,我们只想验证一些细节:您使用的是哪个Windows版本?您是否收到来自特定应用程序的错误消息?
您知道NUC上当前安装的图形驱动程序的版本吗?您可以通过进入“设备管理器”选择“显示适配器”,右键单击英特尔®高清显卡,选择“属性”并选择 “司机”标签。任何问题,请让我知道.Regards,Alberto R. 以上来自于谷歌翻译 以下为原文 rubilacx: We will do our best to assist you with this matter. In order to provide the most accurate response, we just wanted to verify a few details: Which Windows version are you using? Are you getting that error message from a particular application? Do you know the version of the graphics driver currently installed on the NUC? You can see it by getting into "Device Manager" select "Display Adapters", right click where it says Intel® HD Graphics, choose "Properties" and the select the "Driver" tab. Any questions, please let me know. Regards, Alberto R |
rubilacx:我只是想检查您是否看到了我们之前要求的信息以及您是否需要进一步的帮助?有任何问题,请告诉我.Regards,Alberto R
以上来自于谷歌翻译 以下为原文 rubilacx: I just wanted to check if you saw the information we requested previously and if you need further assistance on this matter? Any questions, please let me know. Regards, Alberto R |
我正在运行最新的Windows 10,其中包含从英特尔站点下载的设备的所有更新和最新驱动程序。
奇怪的是,我能够将外部nVidia GPU设置为主监视器。 看起来软件正在查看主显示器以及与之关联的驱动程序。 这可能是某些软件中的常见问题,不确定。 看起来NUC基本上有两个驱动程序集。 一个用于Radeon,另一个用于英特尔。 这些中的一个或两个都支持OpenGL直接状态访问扩展吗? 以上来自于谷歌翻译 以下为原文 I am running the latest Windows 10 with all updates and the latest drivers for the device downloaded from the Intel site. Strangely I was able to get this working with an external nVidia GPU set as primary monitor. It appears like the software is looking at the primary display and whatever drivers are associated there. This may be a common problem among some software, not sure. It appears the NUC has basically two driver sets. One for the Radeon, the other for the Intel on board. Do either or both of these support OpenGL direct state access extension? |
jerry1978 发表于 2018-12-5 09:04 rubilacx:非常感谢你提供这些细节。正如你所提到的,是的,NUC可以使用2种不同的图形控制器,英特尔®UHD图形630和Radeon™RX Vega M图形。我们需要安装的第一个是 一个属于英特尔,版本24.20.100.6229:https://downloadcenter.intel.com/download/28079/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUCs -NUC8i7HxKx?product = 126141然后我们需要安装属于Radeon™版本18.7.1的版本:https://downloadcenter.intel.com/download/28080/Radeon-RX-Vega-M-Graphics-Driver-for -Windows-10-64-bit-for-the-Intel-NUC-NUC8i7HxKx?product = 126141我们也可以尝试更新到最新版本0049:https://www.intel.com/content/www/us/ en / support / articles / 000005850 / mini-pcs.htmlhttps://downloadcenter.intel.com/download/28073/BIOS-Update-HNKBLi70-86A-?product = 126141为了提供最准确的答复,我们只想确认一个 几个细节:NUC的具体型号是什么哟 你正在使用?在游戏或Windows的应用程序中,你在哪里看到这个错误信息?你是否在使用Nvidia卡的机箱? 如果是这种情况,请提供机箱的型号和Nvidia显卡的型号?您使用哪个视频端口将NUC连接到机箱和Nvidia卡?有任何问题,请告诉我。 ,Alberto R. 以上来自于谷歌翻译 以下为原文 rubilacx: Thank you very much for providing those details. As you mentioned, yes, the NUC works with 2 different graphics controllers, the Intel® UHD Graphics 630 the Radeon™ RX Vega M Graphics. The first one that we need to install is the one that belongs to Intel, version 24.20.100.6229: https://downloadcenter.intel.com/download/28079/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUCs-NUC8i7HxKx?product=126141 Then we need to install the one that belongs to Radeon™, version 18.7.1: https://downloadcenter.intel.com/download/28080/Radeon-RX-Vega-M-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUCs-NUC8i7HxKx?product=126141 We can also try a BIOS update to the latest version 0049: https://www.intel.com/content/www/us/en/support/articles/000005850/mini-pcs.html https://downloadcenter.intel.com/download/28073/BIOS-Update-HNKBLi70-86A-?product=126141 To provide the most accurate response, we just wanted to confirm a few details: What is the specific model of the NUC that you are using? Where are you seeing this error message, on an application on a game or in Windows? Are you using an enclosure for the Nvidia card? If that is the case, please provide the model of the enclosure and the model of the Nvidia graphics card? Which video port are you using to connect the NUC to the enclosure and to the Nvidia card? Any questions, please let me know. Regards, Alberto R |
jerry1978 发表于 2018-12-5 09:04 rubilacx:我只想查看您是否看过以前发布的信息,如果您需要进一步的帮助?有任何问题,请告诉我.Regards,Alberto R 以上来自于谷歌翻译 以下为原文 rubilacx: I just wanted to check if you saw the information posted previously and if you need further assistance on this matter? Any questions, please let me know. Regards, Alberto R |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-24 14:00 , Processed in 0.593860 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
