你好,
我遇到了一个我似乎无法解决的奇怪问题。 简而言之,我有一个Hades Canyon NUC,它将运行Ubuntu Server(我已尝试过16.04和18.04 LTS版本),上面有VirtualBox。 由于VirtualBox使用未签名的内核模块,我需要禁用安全启动。 但是,当我通过以下菜单中的复选框禁用安全启动时:高级 - >启动 - >安全启动 - >取消选中安全启动,Ubuntu完全停止启动。 这是我是否尝试从本地磁盘或Ubuntu Flash Drive安装程序启动Ubuntu。 Grub显示,我选择一个启动选项(Ubuntu或安装Ubuntu服务器,具体取决于我是否尝试从本地磁盘或闪存驱动器启动),屏幕变黑(使用HDMI)并且所有USB端口都停止运行(键盘 ,鼠标等...)。 一旦我重新启用安全启动,一切都恢复正常工作..洗涤并重复。 我已经尝试了所有我能想到的东西,却无法找到解决方案。 我已经尝试更新BIOS,清除安全启动数据,以及其他一些功能,但都没有。 有没有人对这个问题有什么想法? 我可以确认UEFI启动仍然启用,我的闪存驱动器是使用UEFI设置的,而不是传统的BIOS。 提前致谢! 以上来自于谷歌翻译 以下为原文 Hello, I'm running into a bit of an odd issue that I can't seem to resolve. In short, I have a Hades Canyon NUC that will be running Ubuntu Server (I've tried 16.04 and 18.04 LTS releases) with VirtualBox on it. Due to the fact that VirtualBox utilizes unsigned Kernel Modules, I need to disable Secure Boot. However when I disable Secure Boot via the checkbox in the following menu: Advanced->Boot->Secure Boot->Uncheck Secure Boot, Ubuntu completely stops booting. This is whether I'm attempting to boot Ubuntu from the local disk, or an Ubuntu Flash Drive installer. Grub displays, I select a boot option (either Ubuntu or Install Ubuntu Server depending on if I'm attempting to boot from local disk or Flash Drive), the screen goes black (using HDMI) and all of the USB ports stop functioning (Keyboard, Mouse, etc...). As soon as I reenable Secure Boot, everything is back in working order..rinse wash and repeat. I've tried everything I can think of and can't find a resolution. I've tried updating the bios, clearing secure boot data, and a few other things, none of which has worked. Does anyone have any ideas on what the issue could be? I can confirm UEFI booting is still enabled and my flash drive is setup with UEFI and not legacy bios. Thanks in advance! |
3个回答
谈谈巧合。
我昨天遇到了同样的问题。 然而要想出一个有效的解决方案。 以上来自于谷歌翻译 以下为原文 Talk about coincidence. I ran into the same issue yesterday. Yet to figure work out a working solution. |
同样,在这一点上,我觉得我已经把它缩小到一个UEFI错误或者我正在做的事情(或者没做的事)真的很愚蠢...老实说,我希望后者。 以上来自于谷歌翻译 以下为原文 Same, at this point I feel like I've narrowed it down to an UEFI bug or something really stupid I'm doing (or not doing)...honestly, I'm hoping for the latter. |
各位大家好,感谢您加入此英特尔社区。我了解您的英特尔®NUC在BIOS中禁用安全启动时不会出现启动问题。
我想提供一些有关此问题的信息。英特尔不会在Linux上测试和验证英特尔®NUC。 但是,我们知道很多英特尔®NUC用户都在许多不同的Linux发行版上成功使用它。 我建议您查看Linux发行版的网站和论坛以获得此查询的同行帮助。 您也可以参考以下这些支持网站:https://askubuntu.com/https://ubuntuforums.org/值得注意的是,您可以确保您的英特尔®NUC是最新的.https:// downloadcenter .intel.com / search?keyword = NUC8i7HNKWanner G. 以上来自于谷歌翻译 以下为原文 Hello all, Thank you for joining this Intel Community. I understand that your Intel® NUC experiencies no boot issues when disabling Secure Boot in BIOS. I would like to provide some information about this issue. Intel does not test and validate Intel® NUC on Linux. However, we know that a lot of Intel® NUC owners are using it successfully on many different Linux distros. I recommend you to check your Linux distro's website and forums for peer assistance with this inquiry. You can also refer to these support websites below: https://askubuntu.com/ https://ubuntuforums.org/ It is worth noting that you can make sure that your Intel® NUC is up to date. https://downloadcenter.intel.com/search?keyword=NUC8i7HNK Wanner G. |
只有小组成员才能发言,加入小组>>
237浏览 0评论
GMT+8, 2024-3-29 06:58 , Processed in 0.549827 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
