你好
对于具有1060和1333 Hz的DP55WB,16GB是最大支持存储器(RAM),但应该选择最佳输出。 8Gb x 2还是4Gb x 4? 谢谢 MEHUL 以上来自于谷歌翻译 以下为原文 Hello 16GB is max supported memory (RAM) for DP55WB with 1060 and 1333 Hz but what is the should be the selection for best output. 8Gb x 2 or 4Gb x 4? Thanks Mehul |
2个回答
当该板被释放时,8GB DIMM不存在,因此从未受到支持。
获得16GB的唯一方法是使用4GBx4。 内容S 以上来自于谷歌翻译 以下为原文 8GB DIMMs did not exist when this board was released and thus were never supported. The only way to get 16GB is with 4GBx4. ...S |
我读过的论坛表明,这个主板在内存方面很挑剔。 我的DP55WB在两个蓝色内存插槽和一个XEON X3450 CPU中运行2x8GB Micron DDR3(总共16GB)。 系统运行良好。 我无法让DP55WB运行32GB内存(所有4个内存插槽都装有8GB DDR3)。 当我尝试时,系统需要永远启动Server 2016并且运行速度非常慢(尽管它确实通过了所有内存测试)。 为了它的价值,我有一个Intel DQ57TM插槽1156主板,带有4x8GB Mushkin ECC无缓冲DDR3(32GB)和一个XEON L3426。 它是一个可靠的Server 2016系统,运行多个Windows和Linux VM(RAID 10中的4个SSD使用板载SATA端口)。 没问题。 系统全天候运行,非常可靠。 我还有一台Biostar TH55HD插座1156主板,配备4x8GB非ECC DDR3(32GB)和Xeon X3450。 它也是一台可靠的Server 2016机器,但不支持RAID。 请记住,Socket 1156的内存控制器位于CPU中,因此了解是否支持所需内存配置的唯一方法是受发布的内存兼容性列表或实验的限制,并自行查找。 以上来自于谷歌翻译 以下为原文 Forums I've read suggest that this board is finicky when it comes to RAM. I have my DP55WB running with 2x8GB Micron DDR3 (total of 16GB) in the two blue memory slots and a XEON X3450 CPU. System runs great. I haven't been able to get the DP55WB to run with 32GB RAM (all 4 memory slots populated with 8GB DDR3). When I tried, the system takes forever to boot Server 2016 and runs extremely slowly (although it does pass all memory tests). For what it's worth, I have an Intel DQ57TM socket 1156 motherboard with 4x8GB Mushkin ECC Unbuffered DDR3 (32GB) and a XEON L3426. It is a solid Server 2016 system running multiple Windows and Linux VMs (4 SSDs in RAID 10 using the onboard SATA ports). No problems. System runs 24x7 and is super reliable. I also have a Biostar TH55HD socket 1156 motherboard with 4x8GB non-ECC DDR3 (32GB) and a Xeon X3450. It's also a solid Server 2016 machine but doesn't support RAID. Remember that the memory controller for Socket 1156 is in the CPU, so the only way to know whether your desired memory configuration is supported is to be limited by the published memory compatibility list or experiment and find out for yourself. |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 15:13 , Processed in 0.544785 second(s), Total 69, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
