嗨!
我最近从赛普拉斯搬到了ST,可能需要帮助在这里起步和运行。 我的最终目标是为250W电机构建无传感器(不一定是FOC)电机控制器,用于大批量应用。 我的软件设置是:st4STM32,Xcube MC SDK,ST32 cube MX 我的问题是无传感器控制工作所需的硬件设置。 MCU,栅极驱动器和6x FET设置到位,但我无法弄清楚MCSDK工作所需的反馈拓扑,即它是否需要外部OPamp来放大电流分流器,还是需要与之配合使用的比较器虚拟中立& backemf线路提供高/低信号,类似于具有相移或其他东西的霍尔传感器? 如果有人能指出我正确的方向,那将是非常有帮助的! 亲切的说明:我以前的经验是有感知的应用程序,所以我理解换向原则。 #电机控制 以上来自于谷歌翻译 以下为原文 Hi! I have recently moved from Cypress to ST, and might need help getting up and running here. My end goal is to build a sensorless (not necessarily FOC) motor controller for a 250W Motor for a high volume application. My software setup is: st4stm32, Xcube MC SDK, ST32 cube MX My issue is with the hardware setup required for the sensorless control to work. The MCU, gate drivers and 6x FET setup is in place, but I cant figure out the feedback topology that is required for the MCSDK to work, i.e. does it need external OPamps to amplify the current shunt or does it need comparators that work with the virtual neutral & backemf lines to give a High/Low signal similar to hall sensors with a phase shift or something else ? If someone can point me in the correct direction that would be of great help! Kind note: My previous experiences have been with sensored applications, so I understand the commutation principles. #motor-control |
3个回答
你好,
您是否已经拥有一些硬件或者您正在设计定制板? 如果您还没有硬件,我建议您查看ST控制板和电源板。 基本上,对于FOC我们不需要Bemf采样(我们需要6步)。我们读到了需要放大的电流。我们支持1个分流器或3个分流器或ICS拓扑结构。如果您使用STM32F303,则可以在外部或内部进行放大,对于用于过流保护的比较器也是如此。 我们的工具配置ST Motorcontrol Workbench允许您配置它。当然,如果从ST报价开始,将会更容易,因为工具已经知道了参数。 一个很好的起点可能是在这里下载我们的5.1.1库: http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-mcsdk.html 它包含配置工具ST Motorcontrol工作台。 问候 塞德里克 以上来自于谷歌翻译 以下为原文 Hello, Do you already have some hardware or are you in the process of designing a custom board ? If you do not have HW yet, I would suggest you to have a look in ST control boards and power boards. Basically, for FOC we do not need Bemf sampling (we need it for 6 steps). We read current that need to be amplified. We support 1 shunt or 3 shunts or ICS topology. Amplification can be done externally or internally if you use a STM32F303 for instance, the same for comparators used for over current protection. Our tool configuration ST Motorcontrol Workbench will allow you to configure this. Of course it will be much easier if you start from ST offer, as parameters are already known from the tool. A good starting point could be the download of our 5.1.1 library here : http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-mcsdk.html it contains the configuration tool ST Motorcontrol workbench. Regards Cedric |
我有一些硬件,它包括:
- 栅极驱动器 - 6个MOSFET设置 - PSOC4 - 基于霍尔传感器的控制 我正试图转向无传感器控制,我将为此制作一块新板。 这是我从你的评论中得出的结论: - 当我以6步骤运行电机时,BEMF需要采样 - 无传感器模式(我不打算) - 对于FOC,我将使用1/3分流型或绝缘电流传感器。 问:当我去设置分流器时,我得到了这个,我应该坚持默认值 - 确保它覆盖我当前的范围或者我是否需要调整增益设置或其他?我错过了配置它的目标。 以上来自于谷歌翻译 以下为原文 I have some hardware, it includes: - Gate drivers- 6 MOSFET setup - PSOC4 - hall sensor based control I am trying to move to sensorless control for which I shall make a new board. This is what I have concluded from your comment: - BEMF is sampling is needed when I run the motor in 6 step - sensor less mode (which I am not planning to) - For FOC I will have to go with a 1/3 shunt profile or insulated current sensors. Q:When I go to setup the shunt, I get this, should I stick to default values - making sure it covers my current range or do I need to adjust the gain settings or something else ? I am missing the objective of configuring this. |
你好,
我真的建议你看看我们的电源板解决方案。我们所有的原理图都是免费提供的。 我不知道你的VBUS是什么,但也许你可以从这个参考开始: http://www.st.com/content/st_com/en/products/ecosystems/stm32-open-development-environment/stm32-nucleo-expansion-boards/stm32-ode-move-actuate-hw/x-nucleo- ihm08m1.html 原理图如下: http://www.st.com/resource/en/schematic_pack/x-nucleo-ihm08m1_schematic.pdf 该板可以同时执行两个操作,3个分流器1分流FOC或六个步骤。保持对你有意义的部分。 当您选择赛普拉斯PSOC4控制器时,我们的工作台工具对您来说毫无用处...... 问候 塞德里克 以上来自于谷歌翻译 以下为原文 Hello, I really advise you to look at our power boards solution. All our schematics are available for free. I do not know what is your VBUS, but perhaps you can start with this reference : http://www.st.com/content/st_com/en/products/ecosystems/stm32-open-development-environment/stm32-nucleo-expansion-boards/stm32-ode-move-actuate-hw/x-nucleo-ihm08m1.html the schematic is here : http://www.st.com/resource/en/schematic_pack/x-nucleo-ihm08m1_schematic.pdf This board can do both, 3 Shunts 1 shunt FOC , or Six steps. keep the parts that make sense for you . As you choose a Cypress PSOC4 controller, our workbench tool will be useless for you ... Regards Cedric |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1445 浏览 1 评论
2113 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2822 浏览 6 评论
5238 浏览 21 评论
361浏览 4评论
537浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
278浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
606浏览 3评论
511浏览 3评论
GMT+8, 2024-4-24 08:55 , Processed in 0.838659 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
