我目前有一台HP4194A分析仪,它运行良好,直到有一天关闭。
在关闭它时它不会再次打开。 后面的风扇将运行,屏幕将打开但不显示任何内容。 前面的两个LED保持点亮位置以及两个处理器板A6和A8上的所有POST灯。 但是,任何一块电路板上的总线停止LED都不亮。 以下是我作为问题的建议解决方案所做的事情列表。 所有电源板和处理器板上的盖子都已更换。 已检查所有电阻值的板A3,A6和A8的公差。 检查所有电压/频率并将其重新调整到服务手册规定的正确电压。 服务手册流程图也引导我走向死胡同。 我相信罪魁祸首绝对是A6-A8板。 在检查来自电源监视器的暂停线之后,处理器也接收正确的电压。 如果有人对这些机器有任何重要经验并遇到类似问题,请分享您的经验。 谢谢! 以上来自于谷歌翻译 以下为原文 I current have an HP4194A Analyzer that functioned fine until it was turned off one day. Upon turning it off it would not turn back on again. The fan in the back will run and the screen will turn on but display nothing. The two LEDS on the front remain in the lit position as well as all the POST lights on the two processor boards A6 and A8. However, the bus halt LED is not lit on either of the boards. Here is a list of things that I have done as a proposed solution to the problem. The caps on all the power supply boards and processor boards have been replaced. All resistor values have been checked for tolerances on boards A3, A6, and A8. All the voltages/frequencies have been checked and readjusted to the correct voltages as specified per the service manual. The service manual flow charts also lead me to dead ends. I believe the culprit is definitely boards A6-A8. The processor is also receiving the correct voltages after checking the halt lines from the power supply monitor. If anyone has any significant experience with these machines and has experienced similar problems please share your experience. Thanks! |
1个回答
解决方案已得到解决。
像这样的分析仪是由于备用电池不良导致分析仪无法启动。 可以通过将5v信号跳到Q1晶体管集电极来解决。 以上来自于谷歌翻译 以下为原文 A solution has been resolved. Analyzers that behave like this are due to a bad backup battery which causes the analyzer to not start. It can be resolved by jumping a 5v signal to the Q1 Transistor collector. |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1385浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
261浏览 0评论
2248浏览 0评论
1102浏览 0评论
GMT+8, 2024-3-29 00:29 , Processed in 1.052111 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
