新版本的英特尔图形驱动程序中存在一个错误。我使用的是其中一个新驱动程序>版本:24.20.100.6194并且所有游戏都被锁定到最大屏幕分辨率为1366x768所以我无法将其更改为1280x720或1024x768
例如,最大分辨率是每个游戏唯一可用的选项。然后我卸载了我的驱动程序并安装了旧版本> 23.20.16.4849现在一切都很好。 我的系统: ---------------- 联想笔记本电脑IdeaPad 3所有游戏都锁定到最大屏幕分辨率10 15ikb 1366x768 screenWindows 10 Creators更新v1703并尝试了Windows 10 April 2018更新v1803 CPU:i7-7500uGPU:Intel HD 620和geforce nvidia 920MX是的,我用nvidia GPU玩所有游戏,因为Intel GPU不是nvidia 以上来自于谷歌翻译 以下为原文 There is a bug in newer versions of Intel graphics drivers. I was using one of the new drivers > version: 24.20.100.6194 And all games was locked to the maximum screen resolution which was 1366x768 so I can't change it to 1280x720 or 1024x768 for example, the maximum resolution was the only available option on every game. Then I uninstalled my drivers and installed an old version > 23.20.16.4849 And now everything is fine. My SYSTEM: ---------------- Lenovo Laptop IdeaPad 310 15ikb 1366x768 screen Windows 10 Creators Update v1703 and Also tried Windows 10 April 2018 Update v1803 CPU: i7-7500u GPU: Intel HD 620 and geforce nvidia 920MX And yeah, I'm playing all games with nvidia GPU and the problem happens because Intel GPU not nvidia |
3个回答
Hellomody0106,我知道你在解决游戏方面遇到了问题。关于这一点,我想首先提一下在开始支持之前我们需要讨论一些信息。
请参考你的私信,我已发给你一个。大卫V. 以上来自于谷歌翻译 以下为原文 Hello mody0106, I understand that you are having problems with the resolution of the games. Regarding this, I would like to start by mentioning that we need to discuss some information before we begin with the support. Please refer to your private messages, I have sent you one. Regards, David V |
jerry1978 发表于 2018-11-30 17:42 我有一个类似的问题,虽然,试图玩罗马总计,屏幕横向移动,减少约3个季度 以上来自于谷歌翻译 以下为原文 I have a similar problem, although, trying to play rome total, the screen goes sideways and cuts by about 3 quaters |
HelloMinibozz97,感谢您的回复。感谢您抽出宝贵时间向我们提供信息,我们将考虑到这一点,但是,对于给您带来的任何不便,我们深表歉意。 请提交一个新主题,因为我们会单独处理每个案例,即使使用相同的产品,每个场景都不同。 下一个代理人将能够进一步帮助你解决这个问题。大卫V. 以上来自于谷歌翻译 以下为原文 Hello Minibozz97, Thank you for your response. I appreciate you taking the time to provide us with information, we will be taking it into consideration, however, we apologize for any inconvenience. Please submit a new thread since we handle every case individually and every scenario is different even if the same product is being used. The next agent will be able to further assist you on this matter. Regards, David V |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-20 00:05 , Processed in 2.319517 second(s), Total 72, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
