嗨,
所以,我正在考虑更换这个(令人难以置信的)整洁机器上的导热膏和焊盘。 我不打算超频,而是取代最好的散热效果(低压和更换热界面材料)。 有人做过它可以分享一些结果吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, So, i'm thinking to replace both the thermal paste and pads on this (incredible) neat machine. I don't plan to overclock but achieving the best thermal results instead (undervolting and replacing thermal interface materials). Has someone done it who could share some results ? Thanks. |
6个回答
除非您的机器是旧的(4年或更长时间或更长时间),否则更换TIM就像更换轮胎中的空气一样。
只是一个意见。 文件 以上来自于谷歌翻译 以下为原文 Unless your machine is OLD (4 years or more or thereabouts), replacing the TIM is like changing the air in your tires. Just an opinion. Doc |
我已经关闭了Turbo Boost并进行了降频,并且在游戏时将温度从95-99降低到82最大,所以它绝对值得。
我听说重做导热膏并想知道是否值得尝试,我很确定我看到了另一个帖子,有人做了它并将温度降低了5度左右。 目前我的闲置时间是48-52,我想让它们降低一点。 以上来自于谷歌翻译 以下为原文 I've turned off Turbo Boost and underclocked and have reduced temps from 95-99 down to 82 max when gaming so it's definitely worth it. I've heard about redoing the thermal paste and wondering if it's worth trying that as well, I'm pretty sure I saw another post where someone did it and reduced temps by 5 degrees or so. Currently my idle temps are 48-52 and I'd like to get them a bit lower. |
好吧,在挖掘之后,我发现如何使用这台机器大幅度降低温度并降低预期温度。
我现在处于40s的CPU处于空闲状态,大约70负载处于负载状态。 GPU的情况大致相同,这些温度适用于轻型3D游戏和浏览网络等机器。 核心电压设置为负160,稳定,HT禁用,涡***率封装时间窗口设置为28。 也就是说,我为VRM订购了真正的高端散热垫,为模具订购了TIM(显然),我喜欢调整并获得最佳效果。 除此之外,自动风扇关闭被禁用,最小风扇转速为35%,以获得更好的空闲温度。 这台机器非常安静,在负载下具有良好的声学效果,我喜欢这样。 现在我的问题是正确拆除机器,最好的方法是什么? 拆下Mobo然后拆下散热器,或者我可以通过直接拧下散热器来移除主板吗? 干杯 以上来自于谷歌翻译 以下为原文 Ok, after digging it, i found how to lower temps drastically and within expected thermals with this machine. I'm now in the 40s for the CPU at idle and around 70 under load. It's about the same for the GPU, these temps are for the machine under light 3D gaming and broswing web and such. Core voltage is set to minus 160, stable, HT disabled, turbo power package time windows set to 28. That said, i ordered really high end thermal pads for the VRM and TIM for the dies (obviously), i love to tweak and achieve the best possible results. Other than that, auto fan off is disabled and min fan rpm to 35%, for better idle temps. This machine is pretty silent, and good acoustics under load, i like that. Now my issue is to tear down the machine properly, what is the best method ? Remove the Mobo and then the heatsink, or can i remove the mobo by unscrewing the heatsink directly ? cheers |
tech_lou 发表于 2018-11-29 12:23 如果你必须: Hades Canyon NUC拆卸和鼓风机 - 冷却解决方案 - YouTube 但它并没有告诉你一切。 以上来自于谷歌翻译 以下为原文 If you must: Hades Canyon NUC Disassembly and Blowers-Cooling Solution - YouTube But it doesn't tell you everything. |
谢谢,从我所看到的,主板应该从散热器上卸下所有螺丝。
我会明白的... 以上来自于谷歌翻译 以下为原文 Thank you, from what i see, the motherboard should come off the heatsink with all screws removed. I'll see... |
我设法拆掉了野兽,这并不容易!
我不建议这样做,破坏单位的风险是真实的! 无论如何,我可以分享我的结果...... 核心电压为-145mV,在-160mV时不稳定 HT关闭,TURBO开启 FAN自动关闭被禁用 工厂的TIM干燥,但接触良好,因此我的设置温度很好。 我用Thermal Grizzly Kryonaut取而代之,我用Fuipoly最高的替换了热垫。 之前:室温在25C~ 之后:室温在25℃〜 CPU和GPU死机的温度相差约2至5摄氏度+ VRM温度。 我觉得这种PC是为发烧友制作的,所以请INTEL,让它易于拆卸,所以我们可以称之为KIT。 我真的希望这更容易服务。 以上来自于谷歌翻译 以下为原文 I managed to tear down the beast, this is not easy ! I don't recommend doing this, the risk of breaking the unit is real! Anyway, i can share my results... Core voltage is at -145mV, it wasn't stable at -160mV HT is OFF, TURBO is ON FAN auto OFF is disabled The TIM from factory was dry, but the contact was good so the temps were good with my settings. I replaced it with Thermal Grizzly Kryonaut, and i replaced the thermal pads with Fuipoly highest ones. BEFORE: room temp at 25C~ AFTER : room temp at 25C~ That's about 2 to 5 degrees Celsius lower on CPU and GPU dies+VRM temps. I feel this kind of PC is made for enthusiasts, so please INTEL, make it easy to tear down, so we can call this a KIT. I really wished that was easier to service. |
只有小组成员才能发言,加入小组>>
234浏览 0评论
GMT+8, 2024-3-19 14:29 , Processed in 0.646163 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
