我有一个HP 8720D VNA,带有选件010(TDR)和1D5(高稳定性时基)。
它应该是cal,但我想知道是否有可能改装选项012 ..这样的升级是否是一个可用的选项? 在实践中,是否可以添加选项? 我不禁感到它可能只是打破一些内部射频电缆并将它们路由到前面板。 使用安捷伦的一些检测工作找到一个零件网站,并搜索“8720D-012”我可以得到所需的零件清单。 零件号码部分描述状态参考价格08720-20026UTG射频电缆-A63 / A66可用至GoneGBP 185.00 08720-20033UTG射频电缆-A62 / A65可用至GoneGBP 92.72 08720-20058UTG射频电缆-S5前面板可用至GoneGBP 100.00 08720-20098CableOrderableGBP 55.63 08720-20104UTG射频电缆前端 Panel InAvailable直到GoneGBP 107.00 08720-20154RF电缆CPL1 FP CPL1Obsolete 08720-20164UTG RF电缆 - A62 / 63(012)可用到GoneGBP 96.42部件“08720-20154”,即“RF电缆CPL1 FP CPL1”已过时,我猜 意味着安捷伦无法适应这种情况,但我怀疑可以制造射频电缆。 选项089(频率偏移模式)只是软件更改,还是需要更改硬件? 我打算很快将此信息发送给安捷伦,因为校准过期,因此需要重新校准。 如果可以添加选项012,我想这样做。 我会向安捷伦英国公司寻求答案,但我经常发现这里的技术帮助更具信息性! DaveEdited:drkirkby于2013年7月26日下午2:12 以上来自于谷歌翻译 以下为原文 I have an HP 8720D VNA with options 010 (TDR) and 1D5 (high stability time base). It is due for cal, but I would like to know whether it would be possible to retrofit option 012.. Was such an upgrade an offically available option? In practice, would it be possilbe to add the option? I can't help but feel it probably consists of just breaking a few internal RF cables and routing them to the front panel. Using a bit of detective work on the Agilent find a part web site, and searching for "8720D-012" I can get what appears to be a list of the parts needed. Part Number Part Description Status Reference Price 08720-20026 UTG RF Cable-A63/A66 Available Until Gone GBP 185.00 08720-20033 UTG RF Cable-A62/A65 Available Until Gone GBP 92.72 08720-20058 UTG RF Cable-S5 Front Panel Available Until Gone GBP 100.00 08720-20098 Cable Orderable GBP 55.63 08720-20104 UTG RF Cable-Front Panel In Available Until Gone GBP 107.00 08720-20154 RF Cable CPL1 FP CPL1 Obsolete 08720-20164 UTG RF Cable - A62/63 (012) Available Until Gone GBP 96.42 Part "08720-20154", which is "RF Cable CPL1 FP CPL1" is obsolete, which I guess means Agilent could not fit this, though I suspect an RF cable could be made up. Also, was option 089 (Frequency Offset Mode) just a software change, or does that require changes to the hardware? I intend sending this to Agilent very soon, as the calibration expires tommorow and so it needs recalibration. If it is possilble to get option 012 added, I would like to do so. I will ask Agilent UK for an answer, but very often I find the technical help on here is more informative! Dave Edited by: drkirkby on Jul 26, 2013 2:12 PM |
1个回答
我后来发现了一个标题为“Agilent 8719ES和8720ES升级套件”的网页http://na.tm.agilent.com/8720/20ESupgrades.htm,它基本上说可以购买这些位并添加选项。
我仍然无法找到P / N 08720-20058的替代品,从服务手册“A63到前面板B-Out”。 我不知道那根电缆是什么,但我怀疑可以制作一根电缆,虽然它可能是非常隐蔽的东西,这是人们无法轻易做到的。 有什么想法吗。 戴夫 以上来自于谷歌翻译 以下为原文 I later found the web page with the title "Agilent 8719ES and 8720ES Upgrade Kits" http://na.tm.agilent.com/8720/20ESupgrades.htm which basically says one can buy the bits and add the options. I'd still be stuck with finding a replacement for P/N 08720-20058, which from the service manual is "A63 to Front Panel B-Out". I've no idea what that cable is, but I suspect one could be made, although it might be something quite obsure, which one could not easily make. Any thoughts. Dave |
只有小组成员才能发言,加入小组>>
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 04:22 , Processed in 0.905435 second(s), Total 44, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
