我的目的很简单,就是通过ADXL345测量三轴加速度,然后计算俯仰角和横滚角。但是我发现,读出的DEVICE_ID是正确的,而三轴加速度值有问题。还有我测量范围调整为2g,ADXL345的XY轴保持水平,三轴寄存器的值在什么范围内是属于正常的,我还不太清楚。
我的ADXL345的初始化过程如下: void ADXL345_Init(void) { SPI0_Send(0x31,0x28); //数据通信格式;设置为自检功能禁用,4线制SPI接口,低电平中断输出,13位全分辨率,输出数据右对齐,2g量程 SPI0_Send(0x1E,0x00); //X轴误差补偿; (15.6mg/LSB) SPI0_Send(0x1F,0x00); //Y轴误差补偿; (15.6mg/LSB) SPI0_Send(0x20,0x00); //Z轴误差补偿; (15.6mg/LSB) SPI0_Send(0x21,0x00); //敲击延时0:禁用; (1.25ms/LSB) SPI0_Send(0x22,0x00); //检测第一次敲击后的延时0:禁用; (1.25ms/LSB) SPI0_Send(0x23,0x00); //敲击窗口0:禁用; (1.25ms/LSB) SPI0_Send(0x24,0x01); //保存检测活动阀值; (62.5mg/LSB) SPI0_Send(0x25,0x01); //保存检测静止阀值; (62.5mg/LSB) SPI0_Send(0x26,0x2B); //检测活动时间阀值; (1s/LSB) SPI0_Send(0x27,0x00); // SPI0_Send(0x28,0x09); //自由落体检测推荐阀值; (62.5mg/LSB) SPI0_Send(0x29,0xFF); //自由落体检测时间阀值,设置为最大时间;(5ms/LSB) SPI0_Send(0x2A,0x80); // SPI0_Send(0x2C,0x0A); // SPI0_Send(0x2D,0x28); //开启Link,测量功能;关闭自动休眠,休眠,唤醒功能 SPI0_Send(0x2E,0x00); //所有均关闭 SPI0_Send(0x2F,0x00); //中断功能设定,不使用中断 SPI0_Send(0x38,0x9F); //FIFO模式设定,Stream模式,触发连接INT1,31级样本缓冲 } 我没有使用中断。 读取三轴加速度值过程如下: void ADXL345_ReadXYZ(INT16S* gx, INT16S* gy, INT16S* gz) { INT16U i; INT8U gbuf[6]; INT16S tempH, tempL; GPIO2DATA &= ~CS; /*读取X轴加速度*/ SSP0DR = 0xB2; while( (SSP0SR & 0x01) == 0 ); //等待TFE置位,即发送FIFO空 SSP0DR = 0x00; while( (SSP0SR & 0x01) == 0 ); gbuf[0] = SSP0DR; SSP0DR = 0xB3; while( (SSP0SR & 0x01) == 0 ); SSP0DR = 0x00; while( (SSP0SR & 0x01) == 0 ); gbuf[1] = SSP0DR; /*读取Y轴加速度*/ SSP0DR = 0xB4; while( (SSP0SR & 0x01) == 0 ); //等待TFE置位,即发送FIFO空 SSP0DR = 0x00; while( (SSP0SR & 0x01) == 0 ); gbuf[2] = SSP0DR; SSP0DR = 0xB5; while( (SSP0SR & 0x01) == 0 ); SSP0DR = 0x00; while( (SSP0SR & 0x01) == 0 ); gbuf[3] = SSP0DR; /*读取Z轴加速度*/ SSP0DR = 0xB6; while( (SSP0SR & 0x01) == 0 ); //等待TFE置位,即发送FIFO空 SSP0DR = 0x00; while( (SSP0SR & 0x01) == 0 ); gbuf[4] = SSP0DR; SSP0DR = 0xB7; while( (SSP0SR & 0x01) == 0 ); SSP0DR = 0x00; while( (SSP0SR & 0x01) == 0 ); gbuf[5] = SSP0DR; for(i=500;i>0;i--); GPIO2DATA |= CS; tempL = (INT16S)gbuf[0]; tempH = (INT16S)(gbuf[1]&&0x1F); *gx = (((tempH<<8)&0xFF00)|(tempL&0x00FF)); tempL = (INT16S)gbuf[2]; tempH = (INT16S)(gbuf[3]&&0x1F); *gy = (((tempH<<8)&0xFF00)|(tempL&0x00FF)); tempL = (INT16S)gbuf[4]; tempH = (INT16S)(gbuf[5]&&0x1F); *gz = (((tempH<<8)&0xFF00)|(tempL&0x00FF)); } 然后通过串口输出gx gy gz 值如下: gx gy gz 01 FF 01 E2 00 56 01 FF 01 E2 00 58 01 FF 01 E2 00 58 01 FF 01 E1 00 58 01 FF 01 E1 00 58 01 FF 01 E2 00 59 01 FF 01 E1 00 58 01 FF 01 DF 00 57 01 FF 01 E0 00 57 01 FF 01 E1 00 57 01 FF 01 E1 00 58 01 FF 01 E0 00 57 01 FF 01 E1 00 57 01 FF 01 DF 00 58 01 FF 01 E0 00 58 01 FF 01 E2 00 57 我发现X轴的加速度一直不变化,求为什么? 还有我不知道读出来的对不对? |
只有小组成员才能发言,加入小组>>
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1307 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
3932 浏览 2 评论
8595 浏览 1 评论
2919 浏览 1 评论
6717 浏览 2 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
714浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
1034浏览 2评论
3932浏览 2评论
962浏览 2评论
745浏览 1评论
GMT+8, 2024-4-24 16:37 , Processed in 0.633762 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
