你好,
我刚设计并填充了一些原型板,这些原型板恰好连接HALL传感器而不是正确的tiM2-5 CHX引脚。 我想知道是否有办法替代使用来自这些通用引脚的HALL信息并将其转发到FOC速度n位置类,而不仅仅是全部扔进垃圾箱? 最好的祝福 #STM32f103 #hall-sensors #foc 以上来自于谷歌翻译 以下为原文 Hello, I've just designed and populated some prototyping boards which happen to connect the HALL sensor not on the correct TIM2-5 CHX pins. Instead of just throwing all in the garbage, I was wondering if is there a way to alternatively use the HALL information from these generic pins and forward it to the FOC speed n position classes? Best regards #stm32f103 #hall-sensors #foc |
4个回答
再见
这并不容易,但我认为您可以尝试使用TIM2或5进行时间测量,这可以在通用GPIO例程中启动和停止。 您可以重复使用转换算法来获取FOC库所需单位的数量速度和位置。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao It is not so easy but I think that you can try using the TIM2 or 5 for the time measurement that can be started and stopped inside a generic GPIO routine. You can reuse the conversion algorithm to get the quantity speed and position in the units that the FOC library expects. Ciao Gigi |
这是我最初的想法。
我想过派生SpeednPosFdbk类。但我无法访问机密分发和SpeednPosFdbk私有类文件。 如何在不派生SpeednPosFdbk课程的情况下注入我的位置和速度读数? 干杯 以上来自于谷歌翻译 以下为原文 That was my initial thought. I thought about deriving SpeednPosFdbk class. But I don't have access to the confidential distribution and SpeednPosFdbk private class files. How can I inject my position and speed readings without deriving SpeednPosFdbk class? Cheers |
我正在获取机密分发。
是派生SpeednPosition类并实现所需方法的最佳方法吗? 你有什么一般建议吗? 以上来自于谷歌翻译 以下为原文 I'm in the process of obtaining the confidential distribution. Is the best method to derive SpeednPosition class and implement the required methods? Do you have any general advice? |
再见
这对我来说并不是很清楚。差异很大?我的意思是,通常虚拟速度传感器的强制角度并不完全是电机的角度,因为它的差异取决于负载。 更好地比较无传感器角度(无意义地运行电机)和传感器的角度。 无论如何,您可以将传感器的角度放在DAC中,并验证形状是否合理。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao It is not all clear for me. The difference is big? I mean that usually the forced angle of the Virtual Speed sensor is not exactly the angle of the motor because it have a difference that depends on the load. Better to compare for instance the sensorless angle (running the motor in senseless) and the angle of your sensors. Anyhow you can put the angle of you sensor in the DAC and verify if the shape is reasonable. Ciao Gigi |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1431 浏览 1 评论
2099 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1509 浏览 1 评论
2818 浏览 6 评论
5227 浏览 21 评论
351浏览 4评论
526浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
596浏览 3评论
507浏览 3评论
GMT+8, 2024-4-23 18:23 , Processed in 0.808784 second(s), Total 75, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
