我有一个85054B校准套件。
如果我使用连接器量规检查套件中的N标准和适配器,则量具表明一切都在规格范围内,但一个适配器略微超出规格(我将替换它)。 如果我用旧的85032B校准套件检查设备,那么事情看起来还不错。 所以这些量具似乎可以与惠普/安捷伦设备配合使用。 但我似乎发现几乎所有非HP / Agilent连接器都不符合规范。 我有两条VNA级测试电缆,带有N型连接器,每端都是Flexco Microwave。 这些是昂贵的电缆,所以我不希望发现所有4个公N连接器都超出规格。 在4个连接器中,都显示进动,但从连接器到连接器有很多不同。 在一根电缆上,两端的进动是* 0.0039“* 0.0136”而在另一根电缆上* 0.0144“* 0.0132”我检查了一个使用过的Radiall衰减器的两端,并且它再次看起来是英里外的。 这些应变计对于它们使用的连接器是否挑剔? 根据该方框,量具的零件编号为85054-80011,与Agilent 85054B套件的当前手册不同,后者列出了设置为85054-60049的量具。 我附上了一套量具。 如果您只能检查HP / Agilent部件,则会降低量具的实用性。 DaveEdited:drkirkby于2014年1月17日下午10:53 以上来自于谷歌翻译 以下为原文 I've got an 85054B cal kit. If I check the N standards and adapters in the kit using the connector gages, the gages indicate everything is within spec, with the exception of one adapter that is slightly out of spec (I'll replace that). If I check the devices in an old 85032B cal kit, again things look ok. So the gages seem to work fine with HP/Agilent devices. But I seem to find almost every non-HP/Agilent connector is *way* out of spec. I have for example two VNA grade test cables with male N connectors each end from Flexco Microwave. These are expensive cables, so I would not expect to find all 4 male N connectors to be out of spec so much. Of the 4 connectors, all show precession, but differing a lot from connector to connector. On one cable, the precession at the two ends are * 0.0039" * 0.0136" And on the other cable * 0.0144" * 0.0132" I checked both ends of a used Radiall attenuator, and again it appears to be miles out. Are these gages fussy about what connectors they work with? According to the box, the part numbers for the gage set are 85054-80011, which is different to the current manual for the Agilent 85054B kit, which lists the gages set as 85054-60049. I've attached a picture of the gages. It rather reduces the usefulness of the gages if you can only check HP/Agilent parts with them. Dave Edited by: drkirkby on Jan 17, 2014 10:53 PM 附件
3个回答
> {quote:title = drkirkby写道:} {quote}>我有一个85054B校准套件。
如果我使用连接器量规检查套件中的N标准和适配器,则量具表明一切都在规格范围内,但一个适配器略微超出规格(我将替换它)。 如果我用旧的85032B校准套件检查设备,那么事情看起来还不错。 所以这些量具似乎可以与惠普/安捷伦设备配合使用。 >>但我似乎发现几乎所有非HP / Agilent连接器都不符合规范。 我有两条VNA级测试电缆,带有N型连接器,每端都是Flexco Microwave。 这些是昂贵的电缆,所以我不希望发现所有4个公N连接器都超出规格。 在4个连接器中,都显示进动,但从连接器到连接器有很多不同。 >>在一根电缆上,两端的进动> * 0.0039“> * 0.0136”>>>另一根电缆> * 0.0144“> * 0.0132”>>我检查了一个二手Radiall衰减器的两端,并再次检查 它似乎远在外面。 >>这些量具对于它们使用的连接器是否挑剔? >>根据包装盒,量具的零件编号为85054-80011,与Agilent 85054B套件的当前手册不同,后者列出了量规设置为85054-60049。 我附上了一套量具。 >>如果只能检查HP / Agilent部件,则会降低量具的实用性。 >> Dave >>编辑:drkirkby于2014年1月17日下午10:53我正等着接收一套SMA连接器量具,我订购了几天。 所以我在看Mauri Microwave网页时发现:Maury的连接器测量套件提供了一种易于使用,直接读取,自检和准确测量大多数*同轴连接器的关键线性接口尺寸*的方法。 顺便说一下,MIL-C-39012第1类的最小值为0.001,标称值为0.001,最大值为0.007。 MIL-C-39012第2类的最小值为0.003,标称值为0.003,最大值为0.040。 Maury High Precision有Min。 0.0000标称0.0000和最大0.0010 Flexco Microwave S系列电缆数据符合MIL-C-39012它没有说什么类。 我希望这有帮助。 以上来自于谷歌翻译 以下为原文 > {quote:title=drkirkby wrote:}{quote} > I've got an 85054B cal kit. If I check the N standards and adapters in the kit using the connector gages, the gages indicate everything is within spec, with the exception of one adapter that is slightly out of spec (I'll replace that). If I check the devices in an old 85032B cal kit, again things look ok. So the gages seem to work fine with HP/Agilent devices. > > But I seem to find almost every non-HP/Agilent connector is *way* out of spec. I have for example two VNA grade test cables with male N connectors each end from Flexco Microwave. These are expensive cables, so I would not expect to find all 4 male N connectors to be out of spec so much. Of the 4 connectors, all show precession, but differing a lot from connector to connector. > > On one cable, the precession at the two ends are > * 0.0039" > * 0.0136" > > And on the other cable > * 0.0144" > * 0.0132" > > I checked both ends of a used Radiall attenuator, and again it appears to be miles out. > > Are these gages fussy about what connectors they work with? > > According to the box, the part numbers for the gage set are 85054-80011, which is different to the current manual for the Agilent 85054B kit, which lists the gages set as 85054-60049. I've attached a picture of the gages. > > It rather reduces the usefulness of the gages if you can only check HP/Agilent parts with them. > > Dave > > Edited by: drkirkby on Jan 17, 2014 10:53 PM I am just waiting to receive a set of connectors gages for SMA that I ordered in afew days. So I was looking at Mauri Microwave web page and found this: Maury's connector gage kits provide an easy to use, direct reading, self-checking, and accurate way to measure the critical linear interface dimensions *of most* coaxial connectors. By the way, MIL-C-39012 class 1 has a min of 0.001 nominal 0.001 Max of 0.007 gap. MIL-C-39012 class 2 has a Min of 0.003 nominal 0.003 and a Max of 0.040 gap. Maury High Precision has Min. 0.0000 nominal 0.0000 and Max of 0.0010 Flexco Microwave S series cables data are conforming to MIL-C-39012 it does not say what class. I hope this helps. |
ianwhoani 发表于 2018-11-23 18:33 > {quote:title = theamberco写道:}>我只是在等待接收一套SMA的连接器量具,这是我在几天内订购的。 >我希望这会有所帮助。 不是真的,因为我的问题是随85054B校准套件提供的特定供应量规(部件号85054-80011),而不是SMA量具。 有没有人有经验使用85054B校准套件上的HP量具,而不是HP / Agilent的连接器? 戴夫。 以上来自于谷歌翻译 以下为原文 > {quote:title=theamberco wrote:} > I am just waiting to receive a set of connectors gages for SMA that I ordered in afew days. > I hope this helps. Not really, as my question is the specific supplied gages (part number 85054-80011) supplied with the 85054B cal kit, not SMA gages. Does anyone have experience using the HP gages from the 85054B cal kit on connectors other than those from HP/Agilent? Dave. |
60user7 发表于 2018-11-23 18:49 > {quote:title = drkirkby写道:} {quote} >> {quote:title = theamberco写道:} >>我只是等待接收一套SMA的连接器量具,我订购了几天。 >>>我希望这会有所帮助。 >>不是真的,因为我的问题是随85054B校准套件提供的特定供应量规(部件号85054-80011),而不是SMA量具。 我给你的那张桌子是N型而不是SMA,它在Maury网页上。 军事规格等级2的最大值为0.040。 我怀疑这些量具只能用于安捷伦。 以上来自于谷歌翻译 以下为原文 > {quote:title=drkirkby wrote:}{quote} > > {quote:title=theamberco wrote:} > > I am just waiting to receive a set of connectors gages for SMA that I ordered in afew days. > > > I hope this helps. > > Not really, as my question is the specific supplied gages (part number 85054-80011) supplied with the 85054B cal kit, not SMA gages. That table I gave you is for N type not SMA it is on the Maury webpage. Military specs class 2 has a max of 0.040. I doubt that those gages can only be used with Agilent. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 11:44 , Processed in 1.066906 second(s), Total 69, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
