发 帖
原厂入驻New
实战多通道高速精密测温仪的全系列设计教程,以实际项目为依托,提升工程师核心竞争力!→点击立即抢购←
[问答] PIC32MZ EC入门工具包启用TCP/IP堆栈时LED1和LED2不工作
321 PIC32 LED 堆栈
分享
HI,一旦我启用Tab/KED1和DEL2上的TCP/IP堆栈不再工作,ReD3就继续工作。LED连接到RH0/1/2。根据DS7000 05147A页,22 RH0/RH1连接到Pt43/44,它们是ETXD2和ETXD3,并且我猜想TCP/IP堆栈没收这些输出。是否有一种简单的方法释放这些输出以使它们再次可用?先发制人,谢谢
以上来自于百度翻译
      以下为原文
    Hi there,
as soon as I enable the TCP/IP Stack on the starter kit LED1 and LED2 don't work anymore, LED3 keeps working. The LEDs are connected to RH0/1/2. According to DS70005147A-page 22 RH0/RH1 are connected to Pin43/44 which are ETXD2 and ETXD3 and I guess that the TCP/IP Stack confiscates these outputs. Is there a simple way to release these outputs to make them usable again?
Thank you in advance,
schmerse
2018-11-23 15:36:10   评论 分享淘帖 邀请回答
4个回答
你没有提到你是否在使用一个示例项目?(如果是这样的话,在进行更改之前先备份它,或者启动一个新项目)。您可以使用Orthin PIN配置器来不配置引脚ETXD2和ETXD3。然后将它们设置为常规数字IO.HTH。
以上来自于百度翻译
      以下为原文
    You did not mention if you are using an example project? (If so back it up first BEFORE making changes - or start a new project).
You can possibly use Harmony pin configurator to un-configure pins ETXD2 and ETXD3. Then set them as regular Digital IO.
HTH
2018-11-23 15:42:41 评论
举报
愚蠢的延迟-让我贴两次…;-)
以上来自于百度翻译
      以下为原文
    Stupid delay - made me post twice...  ;-)
2018-11-23 15:57:32 评论
举报
我差不多能猜到第二个。您没有设置PHY接口来使用RMII。它将尝试使用MII,它需要ETXD2和ETXD3。RMII只需要ETXD1和D0。演示板上的以太网设置为使用RMII。把它改为RMII,你不仅可以让约瑟夫以太网工作,你会得到你的LED回来。
以上来自于百度翻译
      以下为原文
    I can almost 2nd guess this one.   You've not set up the PHY interface to use RMII..   It will be trying to use MII, which needs ETXD2 and ETXD3.    RMII only needs ETXD1 and D0.         The ethernet on the demo boards is setup to use RMII.   Change it to RMII and not only will you make yoru ethernet work, you'll get your LEDS back.
2018-11-23 16:08:59 评论
举报
我正在使用C:\Microchip \ Hyror \ V2Y04\App\TCPI\TCPIpU-UpPyCalp\固件\ TCPIpU-UppLclit.x我在哪里做那些MI/RMII设置?
以上来自于百度翻译
      以下为原文
    I'm working with C:\microchip\harmony\v2_04\apps\tcpip\tcpip_udp_client\firmware\tcpip_udp_client.X
Where do I do those MII/RMII settings?
2018-11-23 16:27:04 评论
举报
只有小组成员才能发言,加入小组>>
44个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
