你好,
我使用ISE 13.2,编译代码时出现许可错误。 你可以帮我吗。 谢谢 Xilinx.lic 2 KB 以上来自于谷歌翻译 以下为原文 Hello, I use ISE 13.2 and I get licence errors when I compile my code. Could you please help me. Thank Xilinx.lic 2 KB |
4个回答
您似乎将“WebPACK”和“System_Edition”许可证合并在一起。
您可以尝试删除或注释掉许可证文件中的以下行吗? INCREMENT Web_Package xilinxd 2012.10永久不计数 5DFD433AFC3D VENDOR_STRING = doctordesign @ free.fr,Web_Package,软件,永久,_207563486_0_0_277 HOSTID = ANY ISSUER =“Xilinx Inc”START = 09-Oct-2011 TS_OK 包装Web_Package xilinxd 2012.10 CEF8961E58D9 COMPONENTS =“PlanAhead WebPACK”OPTIONS = SUITE -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 It seems you combined "WebPACK" and "System_Edition" licenses. Can you please try removing or commenting out the following lines in the license file? INCREMENT Web_Package xilinxd 2012.10 permanent uncounted 5DFD433AFC3D VENDOR_STRING=doctordesign@free.fr,Web_Package,software,permanent,_207563486_0_0_277 HOSTID=ANY ISSUER="Xilinx Inc" START=09-Oct-2011 TS_OK PACKAGE Web_Package xilinxd 2012.10 CEF8961E58D9 COMPONENTS="PlanAhead WebPACK" OPTIONS=SUITE ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我已经尝试在许可证文件中注释掉行,我得到了同样的错误。
让我解释一下我的意思: 一开始我尝试使用WebPack解决方案并重新创建Chipscope不在此包中(我得到错误NgdBuild 1317)。 我从我的电脑上删除了所有软件并安装了新版本的Logic Edition。 管理许可证,但它仍然是相同的。 今天,我试图获得一个新的lisence文件,从管理许可证中删除WebPack,但它仍然是相同的。 我总是得到同样的错误。 帮帮我 Xilinx.lic 1 KB 以上来自于谷歌翻译 以下为原文 I have try commenting out lines in the license file, and I get the same error. Let me explain what append to me : At the beginning I have try using the WebPack solution and remarque that Chipscope was not in this pack (I get error NgdBuild 1317). I have removed all software from my PC and install a new version, Logic Edition. Manage license but, it's still the same. Today, I have try to get a new lisence file, removing WebPack from Manage Licenses but it's still the same. I get always the same error. Help Xilinx.lic 1 KB |
您是否可以通过MAP进行简单设计而无需芯片内核?
如果没有,可能是因为您之前为此计算机生成了30天的评估许可证并且它已过期。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Can you run through MAP for a simple design without chipscope cores? If not, probably because you generated 30-day evaluation license for this machine before and it's expired. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2589 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2062 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2163浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 01:11 , Processed in 0.990012 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
