我正在使用NUC6i7KYK作为数字音乐服务器。
我更新BIOS后安装了Roon ROCK OS。 当我尝试将HDMI端口连接到Denon AVR-X6200W接收器时,我遇到了问题。 我怀疑HDMI 2.0固件升级可以解决我的问题,所以我想尝试一下。 由于我没有在NUC上安装Windows操作系统,我不知道如何安装固件升级。 有谁知道如何在运行Roon ROCK OS的NUC6i7KYK上安装HDMI 2.0固件升级? 它甚至可能吗? 以上来自于谷歌翻译 以下为原文 I am using an NUC6i7KYK for a digital music server. I installed the Roon ROCK OS after I updated the BIOS. I had problems when I tried to connect the HDMI port to my Denon AVR-X6200W receiver. I suspect the HDMI 2.0 firmware upgrade may solve my problem so I want to try it. Since I don't have the Windows OS installed on the NUC, I don't know how to install the firmware upgrade. Does anyone know how to install the HDMI 2.0 firmware upgrade on an NUC6i7KYK running the Roon ROCK OS? Is it even possible? |
8个回答
Roon ROCK不是受支持的操作系统。
你在这里独自一人。 文件 以上来自于谷歌翻译 以下为原文 Roon ROCK is not a supported OS. You are on your own here. Doc |
由于这是“固件”升级,而不是驱动程序更新,如果我要安装Windows 10,运行HDMI 2.0固件升级程序,然后重新安装不支持的操作系统,它是否会保持有效? 以上来自于谷歌翻译 以下为原文 Since this is a "firmware" upgrade, and not a driver update, would it stay in effect if I were to install Windows 10, run the HDMI 2.0 firmware upgrader, and then re-install the unsupported OS? |
ssqq1980 发表于 2018-11-21 08:00 人们会这么认为。 但是,此固件更新是针对支持的操作系统提供的,而不是Roon ROCK。 我们将不得不等待有更多知识的人来确认。 也许N.Scott.Pearson可以评论? 文件 以上来自于谷歌翻译 以下为原文 One would assume so. But, this firmware update is provided/intended for the supported operating systems, not Roon ROCK. We will have to wait for someone with more knowledge to confirm. Maybe N.Scott.Pearson can comment? Doc |
ssqq1980 发表于 2018-11-21 08:00 是的,它对Linux有好处,所以我认为没有任何理由不适合你: https://nucblog.net/2017/03/intel-releases-the-final-hdmi-firmware-for-apollo-and-kaby-lake/ https://nucblog.net/2017/02/apollo-lake-and-kaby-lake-nuc-hd-audio-bitstreaming-firmware-fix/ 莱昂 以上来自于谷歌翻译 以下为原文 Yes, it was good for Linux so, I don't see any reason why it will be not work for you: https://nucblog.net/2017/03/intel-releases-the-final-hdmi-firmware-for-apollo-and-kaby-lake/ https://nucblog.net/2017/02/apollo-lake-and-kaby-lake-nuc-hd-audio-bitstreaming-firmware-fix/ Leon |
飞雪9366 发表于 2018-11-21 08:17 谢谢你的链接,莱昂。 我会尝试并报告结果。 艾伦 以上来自于谷歌翻译 以下为原文 Thanks for the links, Leon. I will try that and report back with the results. Allan |
莱昂是对的; 升级将保持有效并改善Linux O / S中的功能。 请记住,它正在升级LSPcon IC的固件,其作用是将处理器的DP 1.2信号转换为相应的HDMI 2.0信号。 内容S 以上来自于谷歌翻译 以下为原文 Leon is correct; the upgrade will stay in effect and improve things in Linux O/Ss as well. Remember that it is upgrading the firmware for the LSPcon IC, whose job it is to convert the processor's DP 1.2 signal into a corresponding HDMI 2.0 signal. ...S |
状态
我将NUC上的BIOS从053升级到055。 我安装了Windows 10并应用了更新。 我运行了HDMI 2.0固件升级程序,表明NUC已经拥有最新(最终)版本的HDMI固件。 我重新安装了Roon ROCK OS,但是与Denon AVR的HDMI连接仍然存在问题。 我可以将HDMI连接到我的Oppo UDP-205,所以我怀疑问题出在我的Denon AVR上。 感谢所有对此做出回应的人。 每个回复对我都很有价值,我学到了很多东西。 以上来自于谷歌翻译 以下为原文 STATUS I upgraded the BIOS on my NUC from 053 to 055. I installed Windows 10 and applied updates. I ran the HDMI 2.0 firmware upgrade program which indicated that the NUC already had the latest (final) version of the HDMI firmware. I re-installed the Roon ROCK OS, and the problem still exists with the HDMI connection to the Denon AVR. I can connect the HDMI to my Oppo UDP-205, so I suspect the issue is with my Denon AVR. Thanks to everyone who responded to this. Each response was valuable to me and I learned a lot. |
另一种可能性:它是用于英特尔高清显卡的Linux驱动程序。 内容S 以上来自于谷歌翻译 以下为原文 The other possibility: it's in the Linux driver for Intel HD graphics. ...S |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-20 08:43 , Processed in 0.574838 second(s), Total 75, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
