我的PSoC6先锋板上周到达,但Eink 2.7“显示器不工作,因为它不会更新。我在论坛上发现了另一个用户有类似问题的帖子,这个用户购买了一个新的董事会,因此没有对可能出现的问题的见解。
我恰巧有一个2“电子墨水显示器,所以我想我会把这个插入到盾牌,以确认它不是在盾牌本身是有故障的东西。 当我还在学习的时候,我想知道我需要改变哪些参数来配置2.7个“显示,这样我现在可以使用2”显示。 我想从EddiStOne的例子开始,因为这也使用了Eink显示。 这里有一个显示.c文件,其中包含一个屏幕内容.c文件。在“屏幕内容”中,我看到有一个“指令”常数。假设我应该缩短这一点是正确的吗?那形象呢?这会不会太大以至于2个“显示器”?也许最好只是评论一下。 然后有这个参数“CytheEngIrgFrimeT.FrimeBuffer-[CyoEngII帧FrimeStand”; 我看到CythEngIKFrimeLosig大小如下计算:E-ink框架的大小= E-ink图像的大小=(264×176)/ 8=5808字节 所以我想假设我必须改变这一点。我猜如下:(200×96)/ 8=2400字节。 还有别的吗? 以上来自于百度翻译 以下为原文 My PSoC6 Pioneer Board arrived last week but the eInk 2.7" display is not working as it won't update. I found an earlier post on the forum where another user had a similar problem and this user had purchased a new board so no insights given to the likely problem. I just happened to have a 2.0" E-Ink display, so I thought I would plug this one into the shield to confirm that it is not something on the shield itself that is faulty. As I am still learning, I wondered what would I need to change regarding all parameters used to configure the 2.7" display so that I can now use the 2.0" display. I thought to start with the Eddystone example as this uses the eInk display too. Here I see there is a display.c file which includes a screen_contents.c file. Within "screen_contents" I see there is an "instructions" constant. Is it correct to assume that I should shorten this? What about the image? Would this be too big for a 2.0" display? Maybe better just to comment this out. Then there is this parameter "cy_eink_frame_t frameBuffer[CY_EINK_FRAME_SIZE];" I see that CY_EINK_FRAME_SIZE is calculated as follows: Size of an E-INK frame = size of an E-INK image = (264*176)/8 = 5808 bytes So am I correct to assume I simply have to change this. I'm guessing as follow: (200*96)/8 = 2,400 bytes. Anything else? |
8个回答
你好,
请您尝试一下代码示例HTTP://wwwyCysP.com /CE218133,看看它是否有效?如果没有,你可能会有一个有缺陷的显示器。如果那样的话,请告诉我。我会创建一个支持案例来代替你。 不幸的是,你不能使用任何其他电子墨水显示器与盾牌,因为硬件上的盾只支持以下部分: HTTP//www. 如果你有任何其他问题,请告诉我。 当做 尼丁 以上来自于百度翻译 以下为原文 Hello, Can you please try the code example http://www.cypress.com/ce218133 and see if it works? If it doesn't, you might have a defective display. In that case, please let me know. I'll create a support case to get you a replacement. Unfortunately, you can not use any other E-INK displays with the shield since the hardware on the shield supports only the following part: http://www.pervasivedisplays.com/products/271 Please let me know if you have any additional questions. Regards Nidhin |
60user48 发表于 2018-11-19 15:36 嗨,Nidhin 谢谢你的反馈。我已经加载了CE218133 CAPSENSE示例,没有什么可怕的-屏幕不更新。 我注意到红色LED被照亮了。 快速查看代码,这将是由CythGPIOX写入(LedithRead Poor,Redi-Read Num,Redion)触发的;当InTimeDebug功能无法检测到显示时。 我要尝试的2个“展示”也来自普及,但是,想想看,它现在已经有两岁了。 当做 柯林 以上来自于百度翻译 以下为原文 Hi Nidhin Thanks for the feedback. I've loaded the ce218133 capsense example and nothing I'm afraid - the screen does not update. I note that the red LED is illuminated. Having a quick look at the code, would this be triggered by Cy_GPIO_Write(LED_Red_PORT, LED_Red_NUM, LED_ON); when the InitDisplay function fails to detect the display. The 2.0" display I was going to try is also from pervasivedisplays but, come to think of it, it is a couple of years old now. Regards Colin |
wangcong12138 发表于 2018-11-19 15:44 嗨,柯林, “红色LED”意味着尚未检测到电子墨水显示(详见代码示例文档的第5页)。请确保所有的插头都与基板对齐。还检查电子墨水显示器是否通过连接器J5连接到板上是正确的并且不松动。如果你仍然得到红色LED指示,这意味着盾牌是有缺陷的,请回复到我,如果是这样的话,我会开始的过程,让你更换。 当做 尼丁 以上来自于百度翻译 以下为原文 Hi Colin, Red LED on - means that E-INK display hasn't been detected (see the page 5 of the code example documentation for details). Please make sure that the shield is properly plugged in with all pins aligned with the base board. Also check if the E-INK display's connection to the board via connector J5 is proper and not loose. If you still get the Red LED indication, it means that the shield is faulty, Please revert back to me if this is the case, I'll start the process to get you a replacement. Regards Nidhin |
60user48 发表于 2018-11-19 16:04 嗨,Nidhin 是的,我已经多次检查过盾构对准和J5连接。 当做 柯林 以上来自于百度翻译 以下为原文 Hi Nidhin Yes, I've checked both shield alignment and J5 connection multiple times. Regards Colin |
嗨,柯林,
我记得另一个用户在盾上有柏树徽标,对你来说是一样的吗? 当做 塔雷什 以上来自于百度翻译 以下为原文 Hi Colin, I remember the other user had the cypress logo on the shield, is it the same for you ? Regards Tareesh |
是的,没错。好了,DeV套件在显示器上出现了标志。当第一次运行OOB演示时,屏幕没有做任何事情,尽管BLE CAMS和所有演示都使用CyScript应用程序。所以我把屏蔽拉出,推回连接,显示器开始重置,因为它开始部分变黑,然后停下来,再也没有了。 以上来自于百度翻译 以下为原文 Yes, that's correct. Well, the dev kit arrived with the logo on the display. When running the OOB demo for the first time, the screen did not do anything and though the BLE comms and all the demos worked fine with the CySmart app. So I pulled the shield out and pushed back in to check connections and the display started to reset, as in it started to partially go black but then stopped and nothing more after that. |
wangcong12138 发表于 2018-11-19 16:32 一切美好和新… 屏幕开始做一些事情,但永远冻结更多… 以上来自于百度翻译 以下为原文 All nice and new... Screen started to do something but just froze forever more... |
嗨,柯林,
从调试文本中,您已经发布了PSOC 6 BLE先锋套件的电子墨水显示(屏蔽)的问题,好像驾驶员报告了TFT面板破损。我们已经启动了一个技术支持案例,给你一个替代,并让原来的单位进行故障分析。详情请查收邮件。 提前感谢, 尼丁 以上来自于百度翻译 以下为原文 Hi Colin, From the debug text you've posted in Problem with E-ink display (shield) of PSoC 6 BLE Pioneer Kit , it seems like the driver has reported a TFT panel breakage. We've initiated a Tech Support case to give you a replacement and get the original unit back for failure analysis. Please check your mail for details. Thanks in advance, Nidhin |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
324浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 03:39 , Processed in 1.141737 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
