S2600WF服务器主板和R2000WF系列服务器的TPS在附录B(分别为120和125页)中提供了诊断LED解码器,如下所示。
我有一个客户报告POST失败,视频显示器上显示“32”,琥珀色:ON ON ON关闭绿色:ON ON ON在后部诊断LED上看到关闭。 POST进度代码示例表(相同页面)表示该错误是十六进制代码EE(或二进制1110 1110)。 但是,在随后的页面中,没有在TPS中描述的错误代码EE(或二进制1110 1110)。 以上来自于谷歌翻译 以下为原文 The TPS for the S2600WF server board and the R2000WF series servers offer, in Appendix B (pages 120 and 125, respectively), a diagnostic LED decoder., as shown below. I have a customer who reports POST fails, with a "32" on the video display, and Amber : ON ON ON off Green: ON ON ON off seen on the rear diagnostic LEDs. The POST progress code example tables (same pages) indicates that's a error hex code EE (or binary 1110 1110). However, in the pages which follow, there is no error code EE (or binary 1110 1110)described in either TPS. |
17个回答
你好,
我正在审核您的案例,我想与您分享英特尔®服务器主板的代码诊断。使用它来帮助您在系统的开机自检(POST)过程中排除系统挂起问题。 英特尔®服务器主板在后端包含一组八个POST代码诊断发光二极管(LED)。 当每个例程启动时,给这些LED显示给定的POST代码。请检查以下链接:交互式POST代码诊断解码器如果您有任何其他问题,请不要犹豫,让我知道,我将非常乐意为您提供帮助 。最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, I was reviewing your case and I would like to share with you the POST Code Diagnostics for the Intel® Server Board. Use it to assist you in troubleshooting a system hang during a system's power-on self-test (POST) process. Intel® Server Boards include a bank of eight POST Code Diagnostics light emitting diodes (LEDs) at the back edge. As each routine is started, the given POST code number is displayed to these LEDs. Please check the following link: Interactive POST Code Diagnostic Decoder If you have any other question please do not hesitate and let me know and I will be more than happy to assist you. Best Regards, Emeth O |
None 以上来自于谷歌翻译 以下为原文 Hello, Before to answer you the information asked, I would like to gather more information about your server system. Please provide us the complete system configuration and information. Such as: Memory (Brand Name, Model and Speed) CPU Info (Model) and every other component install into this server board. On the other hand, we are looking for the documentation on what code EEh means. However; since it is not documented it is had to provide you an accurate information about this code. Could you please so kind and provide you a picture of the system label in the chassis (top)? Best regards, Emeth O. |
60user173 发表于 2018-11-19 15:07 这证实了Hex代码是EE。 它没有提供解释EEh含义的建议。 以上来自于谷歌翻译 以下为原文 That confirms the Hex code is EE. It does not provide a recommendation of explanation of what EEh means. |
None 以上来自于谷歌翻译 以下为原文 Hello, I would like to know if you have any other question in order to assist you with. If so let me know and I will be more than happy to assist you. Best regards, Emeth O |
你好, 我想问你一些细节,以便找到客户所面临的这一事件的根源。 请检查以下问题: A)服务器系统是否启动进入BIOS? 还是根本不启动? B)您是否仅使用基本组件测试服务器系统? 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, I would like to ask you some details in order to find the root of this incident that you customer has been facing. Please check the questions below: A) Is the server system booting into the BIOS? or is it not booting at all? B) Did you already test the server system only with the basic components? Best Regards, Emeth O. |
None 以上来自于谷歌翻译 以下为原文 Hello, Due to the fact that I have been reviewing this threat and there is no interactions from your end. I am going to proceed with close it once for all. If you have any other question please let us know and we will be more than happy to assist you. Best Regards, Emeth O |
无法启动。 剥离基础,仍然无法启动。 什么是EEh代码? 以上来自于谷歌翻译 以下为原文 Fails to boot. Stripped to basics, still fails to boot. What is the EEh code? |
你好, 由于您的服务器系统未正确初始化,因此可能会发生这种情况。 这个错误代码有很多不同的原因,因此我建议并询问他是否已经使用基本组件测试了系统。 你有没有测试过不同的处理器? 内存RAM? 母板? 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, This could be happening due to your server system is not initializing properly. There are many different reason of this error code, for that reason I suggested and ask you if he already tested the system with the basic components. Have you ever tested a different processor? Memory RAM? Motherboard? Best Regards, Emeth O |
60user173 发表于 2018-11-19 16:37 你好, 我想知道在这种情况下您是否需要更多信息或帮助。 如果是这样,请不要犹豫,让我知道,我将非常乐意为您提供帮助。 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, I would like to know if you will need more information or assistance in this case. If so, please do not hesitate and let me know and I will be more than happy to assist you. Best regards, Emeth O |
60user173 发表于 2018-11-19 16:37 我已经使用已知在其他系统中工作的一组不同的CPU进行了测试,并且使用了完整的不同内存模块集,这个模型也很有用(R2208WFTZS)。 以上来自于谷歌翻译 以下为原文 I have tested with a different set of CPUs known to work in other systems, and with a complete different set of memory modules, also known good from this model (R2208WFTZS). |
cd340823 发表于 2018-11-19 17:03 你好, 当您通过任何机会测试这些组件时,您是否仍然注意到相同的错误代码? 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, When you tested those components by any chance did you still noticed the same error code? Best regards, Emeth O |
当我更换CPU和RAM时,问题仍然存在 请问那些未记录的EEh错误代码的可能原因是什么? 以上来自于谷歌翻译 以下为原文 When I replaced the CPU and RAM, the problem still occurs What are the possible causes for that undocumented EEh error code, please? |
你好, 您是否曾尝试通过移除跳线来设置BIOS配置的默认设置? 另一方面,如果您已经测试了不同的处理器和不同的内存RAM,那么LED的反应没有改变,它可能表明我们主板已损坏。最好的问候, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, Have you ever tried to set at default settings the BIOS configuration by removing the jumper? On the other hand, if you already tested a different processor and a different memory RAM moreover the LED's reaction did not change it could indicate us that the motherboard is damaged. Best regards, Emeth O |
jerry1978 发表于 2018-11-19 17:29 通过跳线和CMOS电池移除重置BIOS。 问题仍然存在。 默认确认所有跳线设置。 问题仍然存在。 以上来自于谷歌翻译 以下为原文 Reset BIOS by jumper, and CMOS battery removal. Issue persists. Confirmed all jumper settings at default. Issue persists. |
你好, 好的,如果你已经通过删除跳线已经执行将BIOS设置为默认设置,那么问题仍然存在。 我们有可能得出结论主板有缺陷。 最好的祝福, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, Ok, if you already performed to set the BIOS at default settings by removing the jumper moreover the issue still persists. We have the possibility to conclude that the motherboard is defective. Best regards, Emeth O |
你好, 如果您有任何其他问题,请告诉我们以便为您提供最准确的信息。最好的问候, Emeth O. 以上来自于谷歌翻译 以下为原文 Hello, Please if you have any other question let me know in order to provide you the most accurate information. Best Regards, Emeth O |
请问那些未记录的EEh错误代码的可能原因是什么? 以上来自于谷歌翻译 以下为原文 What are the possible causes for that undocumented EEh error code, please? |
只有小组成员才能发言,加入小组>>
234浏览 0评论
GMT+8, 2024-3-19 13:24 , Processed in 0.711487 second(s), Total 89, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
