扫一扫,分享给好友
8个回答
你好,
你能不能告诉我们出现的错误代码是什么? 非常感谢, 祝你今天愉快, 最好的祝福, ST NFC / RFID动态标签支持 以上来自于谷歌翻译 以下为原文 Hello, Might you please tell us what is the error code that is appearing?? thanks a lot, have a nice day, best regards, ST NFC/RFID Dynamic tag support |
嗨,
对不起,我并没有假装这种模棱两可的态度。它刚好在MCU的READ结束时,当我下次尝试交互时,手机甚至都没有检测到标签。 我观察到物理上断开连接并重新连接SDA线解决了这个问题。因此,我有两个问题: 可能SDA的上拉状态阻止标签应答给电话吗?在从标签应答期间,MCU会向正确接收的每个字节发送一个ACK回标签。但是,连续的最后一个是NAK。最后NAK的目的是什么? 祝你今天愉快。 - 以上来自于谷歌翻译 以下为原文 Hi, I did not pretend to be this ambiguous on purpose, sorry. It is just at the end of a READ by the MCU, the phone does not even detect the tag when I try to interact next time. I have observed physically disconnecting and reconnecting the SDA line solves this issue. Thus, I have 2 questions:
Have a nice day. -- |
解决了!我没有正确构建DESELECT命令。
但是,在SELECT的几个答案中,仍然存在MCU向TAG发送的最终NAK的问题。这真的是这样吗? 请告诉我。 以上来自于谷歌翻译 以下为原文 Solved! I was not building correctly the DESELECT command. However, there is still the question of the final NAK sent by the MCU to the TAG in several answers to SELECTs. Is this really this way? Please let me know. |
嗨,我看不到你的名字所以我会称你为NFC / RFID动态标签支持
早上好,
我认为突出显示的区域代表了数据表中的错误。 我对吗?我用ACK实现了它,它可以工作,但不适用于最终的NAK。 请告诉我。 以上来自于谷歌翻译 以下为原文 Good morning, I think the highlighted areas represent errors in the datasheet. Am I right? I implemented this with ACKs and it works but not with final NAKs. Please let me know. |
你好 ,
关于I2C协议,必须在M24SR应答读取结束时的STOP之前发送NACK(仅应答)。无论如何,如果在STOP之前发送了ACK,这可以起作用 - 但有时,根据要读取的数据,它无法工作。这是由于I2C协议规范。 因此,下一版数据表将会有一些变化。 祝你今天愉快, 最好的祝福, ST e2e在线支持 以上来自于谷歌翻译 以下为原文 Hello , Regarding I2C protocol, a NACK must be send before the STOP at the end of the M24SR Answer read (answer only). Anyway if a ACK is sent before a STOP, this can work … but sometimes, depending on data to be read, it can not work. This is due to I2C protocol specification. So there will be some change in the next release of the Datasheet. Have a nice day, Best regards, ST e2e online support |
嗨Kazola,大家好!
我是NFC / RFID标签的新手,但我需要使用M24SR64和我的MSP430使用I2C协议。我的projet是一个基本的,我只想用MSP430动态写3个字节然后用RFID中的手机/阅读器检索它们。 我可以在您之前的帖子中了解您计划使用MSP430。由于你的项目似乎工作 |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1445 浏览 1 评论
2113 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2822 浏览 6 评论
5238 浏览 21 评论
362浏览 4评论
538浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
278浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
606浏览 3评论
511浏览 3评论
GMT+8, 2024-4-24 10:54 , Processed in 0.708619 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
