我使用MSSP1作为SPI从机。在MCC->MSSP1-& GT寄存器中,我不能检查应该启用中断的SSPI框,而不是BCI框。如果我进入中断模块,它将不允许我检查CCP1和CCP2,但是其他中断是可以的。我甚至在配置文件中手动启用它,但是MPLAB立即在加载时再次禁用它。我只有两个通知,信息提示告诉我我的CCP使用哪一个计时器。*爬墙?有什么想法吗?
以上来自于百度翻译 以下为原文 I am using MSSP1 as SPI slave. In MCC->MSSP1->Registers I am unable to check the SSPI box that should enable the interrupt, neither the BCLI box for that matter. If I go to the Interrupt Module, it won't allow me to check CCP1 and CCP2 either, but the other interrupts are okay. I have even enabled it manually in the config file, but MPLAB immediately disables it again on load. I only have two Notifications, INFO hints telling me which timer my CCPs are using. *Climbing up the wall* Any ideas? |
2个回答
现在,PIC10/PIC12/PIC16/PIC18MCC库只支持SPI非中断驱动器,因此当SPI模式被选择时,在寄存器视图中不能中断中断。作为一个旁注,I2C是在中断模式下实现的,SPI是在非中断模式下实现的。
以上来自于百度翻译 以下为原文 Hi Cyber, At this moment, the PIC10/PIC12/PIC16/PIC18 MCC library supports only SPI non-interrupt drivers hence interrupts can not be checked in Register View when the SPI mode is selected. As a side note, I2C is implemented in Interrupt mode and SPI is implemented in non-interrupt mode. |
嗨,IonutB,对不起,我没听到你的留言。谢谢你的澄清。我可以在没有生成的中断代码的情况下生存,但是,这并不能解释为什么我不能启用中断——至少中断管理器代码可以被生成并允许我在优先级列表中上下移动。换句话说,我只是自己编写了代码,但是我总是不得不执行合并A。当我重新生成时,这有点烦人。
以上来自于百度翻译 以下为原文 Hi IonutB, Sorry, I missed your message. Thanks for the clarification. I can live without generated interrupt code, but, this doesn't explain why I can't enable the interrupt - at least the interrupt manager code can be generated and allow me to move it up and down the priority list. That said, I just wrote the code myself, but I am constantly having to perform merge actions when I re-generate, which is a bit annoying. |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1749 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2956 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-26 00:28 , Processed in 1.175406 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
