我一直试图使用外部微处理器作为引导加载程序来编程CY8C5868 AXI-LP032。PSoC没有以任何合理的方式响应。我有几个问题:
1。为什么我不能使用P156和P15—7针作为从机(分别为SCL和SDA)? 2。板上的拉力每1K有点强。然而,这还不高于PSoC或主机的当前能力。这就是问题所在吗? 三。我遵循AN60317附注“PSoC 3和PSoC 5LP I2C Bootloader”。在该注释中,它显示了将从属设备设置为固定函数、硬件和任意引脚。我把它连接到P156和7针,并锁定它们。后来,我认为如果没有使用正常的I2C专用引脚,就指定固定函数是没有意义的,所以我用软件地址解码和内部时钟将它改为UDB(虽然我不知道为什么我必须为一个从……指定时钟)。但它的行为完全相同的设置。我在这里做错事了吗? 下面是痕迹。注意,在发送地址(4)之后,故障不是ACK。但是在ACK周期结束时有一个非常小的脉冲。我不知道这是什么,除非PSoC正在尝试ACK,但已经晚了,或者可能是我的主机没有按时发布数据线。但是,即使启动加载设备没有启用,这也会发生,所以我不知道是什么原因造成的。 另外一件事。顶部跟踪导致PSOC5的外部中断,该中断只调用BooLoad AbjyLoad()。中断被触发并进入引导。但是,即使引导加载失败,PSoC也不会重新启动应用程序。指定了5秒超时。重新设置PSoC会再次启动应用程序。 只是不知道从哪里去。希望有人能帮上忙。 问候,Russ 以上来自于百度翻译 以下为原文 I've been trying to use an external microprocessor as a bootloader host to program a CY8C5868AXI-LP032. The PSoC does not respond in any reasonable manner. I have several questions: 1. Is there any reason why I cannot use the P15-6 and P15-7 pins for the slave (as SCL and SDA respectively)? 2. The pull ups on the board are a little strong at 1k each. Still this is not above the current capability of the PSoC, or of the host. Could that be the problem? 3. I am following the AN60317 appnote "PSoC 3 and PSoC 5LP I2C Bootloader." In that note it shows setting up the slave as fixed function, hardware, and any pins. I connected it to the P15-6 and 7 pins and locked them. Later I thought that it did not make sense to specify fixed function if not using the normal I2C specific pins, so I changed it to UDB with software address decode and internal clock (although I don't know why I should have to specify a clock for a slave...). But it behaves exactly the same with either setup. Am I doing something wrong here? Below are the traces. Note that the failure is no ACK after the address (4) is sent. But there is a very small pulse near the end of the ACK period. I have no idea what that is unless the PSoC is trying to ACK but is late, or maybe my host is not releasing the data line on time. But this happens even when the boot loadable device is not enabled, so I don't know what causes it. Another thing. The top trace causes an external interrupt of the PSoC5, That interrupt just calls Bootloadable_load (). The interrupt is getting triggered and it is entering boot. However, even though the bootload fails, the PSoC never restarts the application. There is a 5 second timeout specified. Resetting the PSoC does get the app started again. Just don't know where to go from here. Hope someone can help. Regards, Russ |
1个回答
没有人回答,但我发现了问题所在。数据表上的说明说,除了USB以外,我不能使用USB引脚(35、36)。注释(6)被放置在下一节的下方,我从来没有看到过…
不管怎么说,我正在试图改变一个板的变化,并在测试完成后再次测试。 谢谢,Russ 以上来自于百度翻译 以下为原文 Well no one answered, but I have found the problem. A note on the data sheet says that I cannot use the USB pins (35,36) for anything other than USB. The note [6] was placed below the next section and I never did see it... Anyway I am in the process of trying to haywire up a change to the board and will test again when done. Thanks, Russ |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1653 浏览 1 评论
3406 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
324浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 06:03 , Processed in 0.616023 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
