现想实现28069芯片的AD上电就开始采样,不需要任何事件触发,请问应该怎么设置呢
4 个讨论
60user89 发表于 2018-11-16 07:12 贡献一下调好的代码吧,能用了 EALLOW; AdcRegs.ADCCTL1.bit.ADCREFSEL = 1; // Page485 选择外部VREF AdcRegs.ADCCTL2.bit.ADCNONOVERLAP = 0; // Enable non-overlap mode 0允许重叠/1不允许 AdcRegs.INTSEL1N2.bit.INT1E = 1; //Enabled ADCINT1 AdcRegs.INTSEL1N2.bit.INT1CONT = 1; //Disable ADCINT1 Continuous mode AdcRegs.INTSEL1N2.bit.INT1SEL = 0; //setup EOC0 to trigger ADCINT1 to fire AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; // 同时采样 AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; //set SOC0 channel select to ADCINA0 AdcRegs.ADCSOC1CTL.bit.CHSEL = 8; //set SOC1 channel select to ADCINB0 page510 AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 0; //set SOC0 start trigger on software AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 0; //set SOC1 start trigger on software AdcRegs.ADCSOC0CTL.bit.ACQPS = 6; //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) AdcRegs.ADCSOC1CTL.bit.ACQPS = 6; //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //ADCINT1 trips after AdcResults latch AdcRegs.ADCINTSOCSEL1.bit.SOC0 = 1; //软件触发源ADCINT1 AdcRegs.ADCINTSOCSEL1.bit.SOC1 = 1; //ADCINT2 will trigger SOC0. TRIGSEL field is ignored. //使用ADCSOCFRC1启动 //AdcRegs.ADCSOCFRC1.all = 0X0101; //0000 0001 0000 0001 AdcRegs.ADCSOCFRC1.bit.SOC0 = 1; AdcRegs.ADCSOCFRC1.bit.SOC8 = 1; EDIS; |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
1761浏览 1评论
GMT+8, 2024-4-20 11:58 , Processed in 0.572879 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
