有这个问题 - 在路由器上更改密码 - 问题消失了。
现在在另一个我无法访问路由器的地方我无法连接。 我确实有正确的密码 - 我的手机连接没有任何问题。 驱动程序更新到最新,适配器重置多次 我在网上看到很多这样的问题,但没有坚实的解决方案。 有什么问题? 以上来自于谷歌翻译 以下为原文 Had this problem at on place - changed password on router - problem gone. Now at another place where I dont have access to router I cannot connect. For sure I have correct password - my phone connect without any problems. Driver updated to latest, adapter reseted many times I see many this kind of problems on web but none solid solution. What's the problem? |
4个回答
问题是路由器为wep或wpa安全性所需的无线密码。
要建立连接,必须使用该路由器的密码。 也许您正在PC /笔记本电脑上运行一些清除这些密码的清理软件,因此需要您重新输入它们。 这不是驱动程序问题。 如果您需要更多帮助,请下载并运行此实用程序,然后附加结果。 下载适用于Windows *的英特尔®系统支持 然后,其中一位英特尔支持工程师可以为您提供帮助。 文件 以上来自于谷歌翻译 以下为原文 The issue is the wireless password required by the router for wep or wpa security. To establish a connection, you must use the password for that router. Perhaps you are running some cleanup software on your PC/Laptop that clears these passwords, thus requiring you to re-enter them. This is not a driver issue. If you need more assistance, download and run this utility, then attach the results. Download Intel® System Support Utility for Windows* Then, one of the intel support engineers can assist you. Doc |
mapleasdf 发表于 2018-11-16 13:36 完全脱离主题答案。 Perhaphs的问题是英语不是我的母语。 我知道密码是什么,它可以在我的手机上运行,但是当我尝试使用笔记本电脑进行连接时,它说这是不正确的。 现在清楚了吗? 我在家里遇到了同样的问题,但是当我在路由器上更改了wifi密码(你知道,连接所需的密码)时问题得到解决。 但在这里我无法更改密码,因为我没有,并且无权登录路由器。 我想解决我的wifi卡的问题,因为它不是路由器问题,当我的手机可以没有任何问题连接到它。 以上来自于谷歌翻译 以下为原文 It's completly out of topic answer. Perhaphs the problem is that english is not my native language. I know what the password is, and it works on my phone, but when I try to connect using laptop it says it's incorrect. Is it clear now? I had the same issue at my home, but when I changed wifi password on the router (you know, password that is required to connect) the problem was fixed. But here I cannot change that password, because I dont have, and will not have permission to login to router. I'd like to fix the problem with my wifi card because its not the router problem when my phone can connect to it without any problems. |
0755susan 发表于 2018-11-16 13:43 做我问的问题: 如果您需要更多帮助,请下载并运行此实用程序,然后附加结果。 下载适用于Windows *的英特尔®系统支持 然后,其中一位英特尔支持工程师可以为您提供帮助。 文件 以上来自于谷歌翻译 以下为原文 Do what I asked: If you need more assistance, download and run this utility, then attach the results. Download Intel® System Support Utility for Windows* Then, one of the intel support engineers can assist you. Doc |
0755susan 发表于 2018-11-16 13:43 您好,svandi。感谢您加入英特尔®社区。我想知道您是否还需要帮助。 如果是,请附上上述al.hill要求的报告.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, svandi. Thank you for joining to the Intel® Community. I would like to know if you still need assistance. If so, please attach the report requested by al.hill above. Antony S. |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-24 03:25 , Processed in 0.561813 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
