我找不到关于这个问题的任何其他帖子,所以假设它是我的设置中的东西。
每当我尝试“使用Internet更新时间”时,我会看到“正在工作......”,然后发出蜂鸣声并显示错误消息“无效的网络连接”。 是的,设备已连接到LAN,LAN可以访问互联网。 此网络上的PC使用各种Internet时间服务器而没有问题。 N9923A可以通过LAN使用数据链路软件。 我错过了什么? 以上来自于谷歌翻译 以下为原文 I could not find any other posts on this problem so assume it is something in my setup. Whenever I try to "Update time Using the Internet" I see "Working..." and then a beep and the error message "Invalid Network Connection". Yes, the unit is connected to the LAN and the LAN has access to the internet. PCs on this network use various internet time servers without problems. The N9923A works fine with the Data Link Software over the LAN. What am I missing? |
6个回答
我没有代理,只有LAN交换机和无线路由器。
我尝试将FieldFox放入路由器的访问连接列表中,可以访问任何目的地和任何服务,但仍然看到无效的网络连接。 我也尝试将FF直接连接到路由器(绕过无线)但看到相同的错误。 我终于通过搜索“代理”找到了你提到的另一篇文章,但那里没有任何我尚未尝试过的内容。 惠特 以上来自于谷歌翻译 以下为原文 I have no proxies, only LAN switches and a wireless router. I tried putting the FieldFox in the router's access connection list with access to any destination and any service but still see the Invalid Network Connection. I also tried connecting the FF directly to the router (bypassing the wireless) but see the same error. I finally found the other post you mentioned by searching on "proxy" but there was nothing there that I haven't already tried. Whit |
andrewxuda 发表于 2018-11-15 15:34 似乎有两个人有类似的问题。 我已经让软件团队调查了这个问题。 由于我们无法复制问题,因此难以解决问题。 Afsi Moaveni 以上来自于谷歌翻译 以下为原文 There seems to be two of you with a similar problem. I've asked the software team to look into this. Difficult to trouble-shoot since we cannot duplicate the problem. Afsi Moaveni |
您好,我们无法从FieldFox时间服务器端找到任何问题。 但是,我们会尽力解决任何网络问题。 请给我发一封电子邮件,上面写着您的联系方式(姓名,电子邮件,电话等)。 我已通过私信发送了您的电子邮件地址。 这是我的firstname_lastname@keysight.com问候,Afsi Moaveni 以上来自于谷歌翻译 以下为原文 Hello, We cannot find any issues from the FieldFox time server side. However, we will try our best to trouble-shoot any network issues. Please send me an email with your contact information (name, email, phone, etc). I have sent you my email address in a private message. It is my firstname_lastname@keysight.com Regards, Afsi Moaveni |
dsgdadsad 发表于 2018-11-15 16:08 感谢您帮助我们缩小问题范围......为了使用*更新时间使用Internet *,您需要在FieldFox中使用* DHCP *设置。 使用+ STATIC IP此时不起作用(固件版本A.07.76或更低版本),因为我们没有DNS服务器的输入字段。 我们将在未来添加。 因此,目前,用户需要使用DHCP,并确保在选择DHCP后按*“应用设置”“立即”*。 Afsi Moaveni 以上来自于谷歌翻译 以下为原文 Thank you to wreeve for helping us narrow down the issue... In order for the *Update Time Using Internet* to work, you need to use the *DHCP* setting in FieldFox. Using a +STATIC IP does not work+ at this time (firmware revision A.07.76 or lower) as we do not have an entry field for DNS server. We will add that in the future. So for now, users need to use DHCP and to also be sure to press *"Apply Settings" "Now"* after they have selected DHCP. Afsi Moaveni |
dsgdadsad 发表于 2018-11-15 16:26 是的,我可以确认将仪器设置为DHCP修复了问题。 需要向下滚动到菜单列表的底部并立即应用。 这是一个瞬时设置,但是DHCP必须获取地址和DNS服务器。 以上来自于谷歌翻译 以下为原文 Yes, I can confirm that setting the instrument to DHCP fixed the problem. It is necessary to scroll down to the bottom of the menu list and Apply Now. This is a momentary setting but is necessary for the DHCP to obtain an address and a DNS server. |
Afsi,为什么要设置时钟这个限制?
我可能会猜测它会阻止人们延长试用许可证,但如果是这样的话,它似乎是一种相当弱的方法,因为有两种显而易见的方法可以将时间设置为你想要的东西。 *将固件降级到旧版本,让您可以设置时钟,然后再次升级固件。 *使用配置为报告错误时间的NTP服务器。 鉴于NTP软件是开源的,运行自己的ntp服务器是非常简单的,该服务器被配置为报告错误的时间。 我很困惑这个限制是什么意思。 戴夫 以上来自于谷歌翻译 以下为原文 Afsi, Why is this limit put on setting the clock back? I might guess it is to stop people extending trial licenses, but it seems to a pretty weak method if that is the case, since there are two obvious ways to set the time to something you want. * Downgrade the firmware to an older release that lets you set the clock back, then upgrade the firmware again. * Use an NTP server which is configured to report the wrong time. Given the NTP software is open-source, it would be trivial to run ones own ntp server which was configured to report the wrong time. I'm just puzzled what the point of this restriction is. Dave |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1855 浏览 1 评论
1714 浏览 5 评论
2581 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 21:35 , Processed in 1.340960 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
