嘿,
我正在将主题“/ camera / depth / camera_info”和“/ camera / depth / image_rect_raw”从D435录制到包文件中。 在播放包文件时,我想启动一个节点,将深度图像转换为pointcloud2消息。 因此我认为我必须使用“depth_image_proc / point_cloud_xyz”。 这是您在启动文件中执行此操作的方式: 。 。 。 但在你的情况下,总是在运行realsense节点。 我认为这就是为什么你可以使用带有指针的nodelets的原因。 在我的例子中,nodelet不起作用。 这是正确的吗? 如何从包文件生成poincloud2消息? 或者我是否必须记录“realsense2_camera_manager”中的其他主题来模拟正在运行的实际节点? 谢谢你的帮助! 以上来自于谷歌翻译 以下为原文 Hey, I'm recording the topics "/camera/depth/camera_info" and "/camera/depth/image_rect_raw" from D435 to a bag file. While playing the bag file I would like to start a node that converts the depth image to a pointcloud2 message. I think therefore I have to use "depth_image_proc/point_cloud_xyz". This is how you do it in your launch files: .But in your cases always the realsense node is running. I think that's the reason why you can use nodelets with pointers. In my case a nodelet is not working. Is this right? How can I generate a poincloud2 message from a bag file ? Or do I have to record other topics from "realsense2_camera_manager" to simulate a running realsense node ? Thanks for your help! |
3个回答
我不确定这是否是您所需要的,但我通过在Google上搜索“depth_image_proc示例”一词来获得看似有用的结果。
以下是搜索中的几个示例: 示例ROS启动文件,它使用depth_image_proc将RGB深度图像对转换为点云·GitHub https://answers.ros.org/question/216748/how-to-use-depth_image_procpoint_cloud_xyzrgb-nodelet-with-ro***ag/ 以上来自于谷歌翻译 以下为原文 I'm not sure if this is what you needed, but I got results that seemed useful by searching Google for the term 'depth_image_proc example'. Here's a couple of examples from a search: Example ROS launch file that uses depth_image_proc to convert an RGB-depth image pair into a point cloud · GitHub https://answers.ros.org/question/216748/how-to-use-depth_image_procpoint_cloud_xyzrgb-nodelet-with-ro***ag/ |
nywerwer 发表于 2018-11-15 19:00 我也看过这些例子,但很困惑,因为他们都使用OpenNI,这是不支持的。 仔细看后,我发现在我的情况下,我不需要OpenNI相机驱动程序。 它有效,谢谢! 以上来自于谷歌翻译 以下为原文 I've also seen these examples, but was confused because they all use OpenNI, which is not supported by realsense. After taking a closer look I saw that in my case I don't need the OpenNI camera drivers. It works, thanks ! |
nmcz 发表于 2018-11-15 19:18 我很高兴它对你有用 - 感谢让我们知道! 以上来自于谷歌翻译 以下为原文 I'm very glad it worked for you - thanks for letting us know! |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-24 18:48 , Processed in 0.677918 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
