大家好,
我收到以下错误,请让我知道解决方案。 工具:ISE 14.6 设备:virtex 6 错误:位置:1377 - 区域时钟网络“u_ddr3 / u_memc_ui_top / u_mem_intfc / phy_top0 / clk_rsync”不能在不同时钟区域锁定负载的情况下路由,因此源不可能路由到所有负载。 请参阅下面的每个时钟区域中的示例锁定组件列表。 有关时钟区域规则的更多信息,请参阅体系结构用户指南。 要使用部分路由设计调试您的设计,请允许mapper / placer完成执行(通过将环境变量XIL_PAR_DEBUG_IOCLKPLACER设置为1)。 错误:位置:1377 - 区域时钟网络“u_ddr3 / u_memc_ui_top / u_mem_intfc / phy_top0 / clk_rsync”不能在不同时钟区域锁定负载的情况下路由,因此源不可能路由到所有负载。 请参阅下面的每个时钟区域中的示例锁定组件列表。 有关时钟区域规则的更多信息,请参阅体系结构用户指南。 要使用部分路由设计调试您的设计,请允许mapper / placer完成执行(通过将环境变量XIL_PAR_DEBUG_IOCLKPLACER设置为1)。 谢谢娜文G K. 以上来自于谷歌翻译 以下为原文 Hi all, I am getting the below error, please let me know the solution. Tool: ISE 14.6 Device: virtex 6 ERROR:Place:1377 - Regional clock net "u_ddr3/u_memc_ui_top/u_mem_intfc/phy_top0/clk_rsync<0>" is not routable with loads locked in different clock regions such that it will be impossible for the source to be routed to all loads. See below for a list of sample locked components in each clock region. For more information on the clock region rules, please refer to the architecture user's guide. To debug your design with partially routed design, please allow mapper/placer to finish the execution (by setting environment variable XIL_PAR_DEBUG_IOCLKPLACER to 1). ERROR:Place:1377 - Regional clock net "u_ddr3/u_memc_ui_top/u_mem_intfc/phy_top0/clk_rsync<0>" is not routable with loads locked in different clock regions such that it will be impossible for the source to be routed to all loads. See below for a list of sample locked components in each clock region. For more information on the clock region rules, please refer to the architecture user's guide. To debug your design with partially routed design, please allow mapper/placer to finish the execution (by setting environment variable XIL_PAR_DEBUG_IOCLKPLACER to 1). Thanks Naveen G K |
4个回答
嗨@ naveengk14,
区域时钟缓冲器(BUFR)最多只能到达相同或垂直相邻时钟区域的负载。 如果负载受限于其他地方,您将看到此错误。 要进行调试,请设置变量,然后在FPGA编辑器中检查生成的不可路由NCD,以确定导致问题的负载。 检查这些负载的约束。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @naveengk14, At best a regional clock buffer (BUFR) can only reach loads in the same or vertically adjacent clock region. If the loads are constrained elsewhere you will see this error. To debug, set the variable and then examine the resulting unroutable NCD in FPGA Editor to determine which loads are causing the problem. Examine the constraints for those loads. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
你好@ naveengk14
你在使用MIG IP吗? 如果您在MIG IP生成后修改了MIG IO引脚排列,则在MIG中使用“验证UCF和更新设计”选项,并为新的MIG UCF重新生成MIG RTL。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @naveengk14 Are you using MIG IP? In case if you have modified the MIG IO pinout after MIG IP generation then use "verify UCF and update design" option in MIG and regenerate MIG RTL for new MIG UCF. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
你好@ naveengk14
你有没有尝试过早期帖子的建议? 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @naveengk14 Did you try the suggestions from earlier posts? Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
喜
我遇到了同样的问题,但有点不同。 在示例设计中,我使用了MIG推荐的ucf,没有发生错误。 但在我添加其他用户逻辑后,发生此错误。 那么,我该怎么办? 以上来自于谷歌翻译 以下为原文 hi, I have met the same question, but a little different. in the example design, I used the ucf which recommended by MIG and no error occured. but after i added other user logic , this error occured. so ,what can i do? |
只有小组成员才能发言,加入小组>>
2162 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2077 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2192 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-24 01:03 , Processed in 1.026277 second(s), Total 76, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
