我在新的NUC7CJYH中安装了8GB Ram和120GB SATA SSD WD GREEN。
启动BIOS时,我找不到SSD。 看起来没有安装任何。 还有一个复选框,我可以选择SSD。 我正在使用UBUNTU 18.04.1的USB设备启动NUC。 SSD有什么限制吗? 有人可以帮忙吗? 谢谢 以上来自于谷歌翻译 以下为原文 I installed 8GB Ram and the 120GB SATA SSD WD GREEN in my new NUC7CJYH. when starting the bios, I cannot find the SSD. It looks like that there isn't installed any. There is also a checkbox where I can choose SSD. I'm starting the NUC with a USB device with UBUNTU 18.04.1. Are there any restrictions for the SSD? Can anyone help here? Thank you |
4个回答
在这里,您可以看到NUC的兼容产品列表:http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName = Intel%C2%AE%20NUC& productType = Kits& pr ...虽然WD Green不在此
列出它并不意味着它不兼容。 这意味着Inet未对其进行验证和测试。 为避免此类问题,最好购买英特尔与NUC测试的产品。 莱昂 以上来自于谷歌翻译 以下为原文 Here you can see the list of compatible products for your NUC:http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC&productType=Kits&pr… Although WD Green is not on this list it doesn't means that it is not compatible. It means that wasn't verified and tested by Inet. In order to avoid such questions, it is better to buy products tested by Intel with NUC. Leon |
飞雪9366 发表于 2018-11-14 14:18 莱昂, 英特尔验证列表相当有限。 根据用户体验对列表进行补充可能是很好的补充。 作为实验,我开始列出NUC7PJYH:SSD兼容性列表 彼得 以上来自于谷歌翻译 以下为原文 Leon, Intel Validated lists are rather limited. It might be good supplement them with lists based on user experience. As an experiment, I started such list NUC7PJYH: SSD Compatibility List Peter |
谢谢你的窍门。 现在我发现了问题:没有连接到内部ssd的外壳顶部的内部连接。 现在它也适用于wd green。 以上来自于谷歌翻译 以下为原文 thank you for your tipps. Now I found the problem: The internal connection to the top side of the housing with the ssd inside wasn't connected. Now it works also with the wd green. |
很高兴听你这样说。 我更新了表格中的状态。 感谢您的输入。 以上来自于谷歌翻译 以下为原文 Glad to hear that. I updated the status in the table. Thanks for your input. |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-24 02:05 , Processed in 0.603152 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
