你好,
面对错误 [选项31-67]问题:设计中的LUT3单元缺少输入引脚I0上的连接,LUT方程使用该连接。 该引脚在设计中未被连接,或者由于未使用的逻辑的修整而移除了连接。 LUT单元格名称为:i_design_1 / design_1_i / uhdsdi_gt_wrapper / uhdsdi_gt / uhdsdi_gt_0 / inst / gt_ch_cpllrefclksel_i_inferred_i_1 在实施过程中 发现很难解决这个意想不到的问题。 可能是什么原因,有人可以帮助我吗? 问候, 维奈 以上来自于谷歌翻译 以下为原文 Hello, Facing an error [Opt 31-67] Problem: A LUT3 cell in the design is missing a connection on input pin I0, which is used by the LUT equation. This pin has either been left unconnected in the design or the connection was removed due to the trimming of unused logic. The LUT cell name is: i_design_1/design_1_i/uhdsdi_gt_wrapper/uhdsdi_gt/uhdsdi_gt_0/inst/gt_ch_cpllrefclksel_i_inferred_i_1 during implementation. Finding difficult to solve this unexpected issue. What could be the reason for this and can someone help me up with this? Regards, Vinay |
6个回答
嘿,我跟踪并检查了合成原理图中的信号,发现由于修剪了未使用的逻辑,连接被删除了。我找到了解决方案。谢谢,Vinay
在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hey, I traced and checked the signal in the synthesized schematics and found that the connection was removed due to the trimming of unused logic. I have found the solution. Thanks, VinayView solution in original post |
@vinay_shenoy,
您使用的是哪个vivado版本? 请检查以下答案记录,看看是否有帮助: https://www.xilinx.com/support/answers/70111.html 您需要在xdc中应用以下约束: set_property DONT_TOUCH true [get_cells i_design_1 / design_1_i / uhdsdi_gt_wrapper / uhdsdi_gt / uhdsdi_gt_0 / inst / gt_ch_cpllrefclksel_i_inferred_i_1] --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @vinay_shenoy, Which vivado version are you using? Please check the following answer record and see if it helps: https://www.xilinx.com/support/answers/70111.html You need to apply the following constraint in your xdc: set_property DONT_TOUCH true [get_cells i_design_1/design_1_i/uhdsdi_gt_wrapper/uhdsdi_gt/uhdsdi_gt_0/inst/gt_ch_cpllrefclksel_i_inferred_i_1] --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨,我尝试通过包含上面的set_property参数进行编译,我没有看到任何改进。
错误仍然存在。我正在使用Vivado 18.1版本请让我知道任何解决这个问题的方法,Vinay 以上来自于谷歌翻译 以下为原文 Hi, I tried compiling by including above set_property parameter and I don't see any improvements. The error still remains. I am using Vivado 18.1 version Please let me know any solution to this problem Regards, Vinay |
@vinay_shenoy,
检查日志文件并查看是否已考虑DONT_TOUCH约束。 如果不考虑约束,那么您将看到严重警告。 你可以共享后期综合dcp文件来调试问题吗? --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @vinay_shenoy, Check the log file and see if the DONT_TOUCH constraint has considered. If the constraint is not considered then you will see Critical warning. Can you share the post synthesis dcp file to debug the issue? --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
以上来自于谷歌翻译 以下为原文 Hey, I traced and checked the signal in the synthesized schematics and found that the connection was removed due to the trimming of unused logic. I have found the solution. Thanks, Vinay |
@vinay_shenoy,
感谢更新。 在问题得到解决后,请通过标记提供解决方案的帖子“接受为解决方案”来关闭此主题。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @vinay_shenoy, Thanks for the update. As the issue is resolved, please close this thread by marking the post which has provided the solution as "Accept as solution" --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 10:17 , Processed in 0.996487 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
