The AS3UA6313CR is a switches combo of High-Speed Data/Hi-Fi Audio and Side Band Use (SBU). It
operates dual power supplies of VBUS and VBAT, either of which can power-up the chip. The Audio path is with low distortion, high swing capability that features Ron of 1.2Ω (typical) at VBAT=3.3V. With very sound THD+N performance, it is an ideal device for Hi-Fi system applications. The USB path bandwidth is wide enough (>900MHz) to pass high-speed USB 2.0 differential signals (480 Mb/s) with good signal integrity. The Side Band Use (SBU) configures internal switches to Ground and MIC connections on a headphone connector. The Ground switch has a low Ron of 0.3Ω (typical) to minimize voltage drop across it, preventing undesired increase in headphone ground reference voltage. Furthermore, a GND sense path supports quasidifferential amplifier architectures, which helps reduce cross-talk between R and L and improve sound quality. In addition, SBU ports (40MHz bandwidth) can be configured as UART Tx/Rx ports or to transmit eDP AUX signals (1MHz).
USB音频方案,USB声卡方案,typec耳机方案 |
现在用交流通过整流滤波稳压之后的电压(正负电压),直接给运放进行供电,实现不了。在PSPICE中仿真会报错。
138 浏览 0 评论
430 浏览 0 评论
862 浏览 0 评论
515 浏览 0 评论
1806 浏览 1 评论
13947 浏览 145 评论
【小车设计挑战赛系列】各类智能小车开源设计资料,原理图、代码齐全
209271 浏览 134 评论
14511 浏览 48 评论
GMT+8, 2024-4-25 17:09 , Processed in 0.595672 second(s), Total 69, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
