嗨团队,
我正在使用SPC560b-Discover板 IDE-SPC5 Studio,版本:5.2.1 我想查找Flash(dataFlash或CodeFlash)和RAM中是否有任何内存损坏。 你能帮我找一下记忆腐败的方法, 据我所知,将会有一种搁浅的方式来启用ECC,或者默认启用它, 如果只是ECC的方式, 如何在SPC560B系列MCU中启用ECC,如果启用ECC,我们将如何知道存在内存损坏。 --- 提前致谢, 谢谢&问候, Mujeeb Shaik。 以上来自于谷歌翻译 以下为原文 Hi Team, I am using SPC560b-Discover board IDE-SPC5 Studio, version: 5.2.1 I want to find if any memory corruptions in Flash(dataFlash or CodeFlash) and RAM. Can you please help me to find the ways of memory corrupt happened, As i know there will be one stranded way to find is enable ECC or by default it will be enabled, If ECC is only the way, how to enable the ECC in SPC560B family MCUs,If ECC is enabled how we will come to know there is memory corruption is happened. --- Thanks in advance, Thanks & Regards, Mujeeb Shaik. |
3个回答
你好Mujeeb,
这有中断 Vector35 0x088C 4 ECC_DBD_PlatformFlash | ECC_DBD_PlatformRAM 平台ECC双位检测 Vector36 0x0890 4 ECC_SBC_PlatformFlash | ECC_SBC_PlatformRAM 平台ECC单比特校正您可以启用它。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Mujeeb , there is an interruption for that Vector35 0x088C 4 ECC_DBD_PlatformFlash | ECC_DBD_PlatformRAM Platform ECC Double Bit Detection Vector36 0x0890 4 ECC_SBC_PlatformFlash | ECC_SBC_PlatformRAM Platform ECC Single Bit Correctionyou can enable it. Best regards Erwan |
嗨二湾,
感谢您的回复,我理解这一点,但我需要帮助使用SPC5 studio为此中断生成回调代码,能否指导我如何生成此中断的代码。 提前致谢, --- 谢谢&问候, Mujeeb Shaik。 以上来自于谷歌翻译 以下为原文 Hi Erwan, Thanks for your reply,I understand this,but i need help to generate call backs code for this Interrupts using SPC5 studio,Can you please guide me how to generate the code for this interrupts. Thanks in advance, --- Thanks & Regards, Mujeeb Shaik. |
嗨Mujeeb,
有一个有用的应用笔记 http://www.st.com/content/ccc/resource/technical/document/application_note/57/02/dc/4a/8e/66/43/ad/DM00080495.pdf/files/DM00080495.pdf/jcr:内容/翻译/ en.DM00080495.pdf 应该调用来自IVOR4的处理程序vector36和vector35。 建议也检查IVOR2(参见文件) 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hi Mujeeb , There is a useful application notes for http://www.st.com/content/ccc/resource/technical/document/application_note/57/02/dc/4a/8e/66/43/ad/DM00080495.pdf/files/DM00080495.pdf/jcr:content/translations/en.DM00080495.pdf
the handler vector36 and vector35 from IVOR4 should be called. it is recommended to check IVOR2 too (cf document) Best Regards Erwan |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1445 浏览 1 评论
2113 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2822 浏览 6 评论
5238 浏览 21 评论
362浏览 4评论
538浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
278浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
607浏览 3评论
511浏览 3评论
GMT+8, 2024-4-24 11:20 , Processed in 0.888433 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
