嗨,我在Z270游戏专业版上安装了一个7700K,配备了Cooler Master MLX-D24M-A20PC-R1(MasterLiquid ML240R RGB | Cooler Master)水冷,带有陶瓷导热膏。
Netherless,我的CPU似乎在游戏过程中过热(在我开始播放后的几分钟,机组2上的电脑节流和崩溃(黑屏),以及今天在使用iGPU插入第二台显示器时使用iGPU进行覆盖时崩溃, 显示铬)我在40°C左右闲置,我通过了英特尔处理器诊断工具。 我很确定崩溃不是来自外部源,因为我有1060 6go,8 gig的DDR4 RAM和ssd。 此外,电脑工作时间很长,使用CPU提供导热膏。 我不得不改为WC,因为我明显遇到了热量问题(在压力测试时达到100°C)现在,我可以根据任务经理进行重负荷压力测试100%的CPU使用情况 80°C(我仍然觉得很热,但我不是一个大专家.WhoCrashed没有报告任何失败,所以我没有任何线索为什么我的电脑崩溃。它还能过热吗? 以上来自于谷歌翻译 以下为原文 Hi, I have a 7700K mounted on a Z270 gaming pro, with a Cooler master MLX-D24M-A20PC-R1 (MasterLiquid ML240R RGB | Cooler Master ) watercooling, with ceramic thermal paste. Netherless, my CPU seems to overheat when gaming (pc throttles and crashes (black screen) on the crew 2, a few moments after i start playing, and today crashed while playing overwatch with a second monitor pluged in on the mb, using iGPU, to display chrome) I idle at around 40°C, and i passed the intel processor diagnostic tool. I'm pretty sure the crashes doesn't comes from an external source, since i have a 1060 6go, and 8 gigs of DDR4 RAM with and ssd. Also, the pc worked fine for quite a time, with thermal paste delivered with the CPU. I had to change to a WC since i clearly had a heat problem (getting to 100°C while stress testing) Right now thougth, i can run a heavy load stress test a 100% of CPU usage according to the task manager while hitting around 80°C (wich i still find quite hot, but i'm not a big specialist. WhoCrashed doesn't report any failure, so i have no effin clue to why my pc is crashing. could it still be overheating ? [color=#555555 !important] |
2个回答
您好Punga,感谢您加入此英特尔社区。根据提供的信息,您的系统符合规格。
有关温度的更多信息,请访问https://ark.intel.com/.Intel®Core™i7-7700K Processorhttps://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M -Cache-up-to-4_50-GHz此外,报告的温度是预期的,因为您正在运行要求苛刻的游戏/应用程序,温度变化是正常的。 但是,我想看看英特尔®处理器诊断工具报告。 请运行它并将其附加到此线程。要附加文件,您必须单击响应框右上角的“使用高级编辑器”,然后“附加”选项将出现在该文本的右下角。 响应框。 - 您是否尝试过加载默认BIOS设置? - 处理器的内存和图形是否超频?另外,请记住,BIOS通常会报告是否发生了热事件.Wanner G. 以上来自于谷歌翻译 以下为原文 Hello Punga, Thank you for joining this Intel Community. Based on the information provided, your system is running within specifications. Please check more information about temperatures on https://ark.intel.com/. Intel® Core™ i7-7700K Processor https://ark.intel.com/products/97129/Intel-Core-i7-7700K-Processor-8M-Cache-up-to-4_50-GHz Also, the temperature reported is expected since you are running demanding games/applications and temperature variation is normal. However, I would like to take a look at the Intel® Processor Diagnostic Tool report. Please run it and attach it to this thread. To attach a file, you must click “Use Advanced Editor” on the upper right hand corner of the response box, then the “attach” option will appear on the bottom right hand corner of the response box. -Have you tried loading default BIOS settings? -Is the processor's memory and graphics overclocked? In addition, keep in mind that BIOS usually reports if a thermal event has occured. Wanner G. |
HelloPunga,您能按照上面提供的步骤进行操作吗?Wanner G.Intel客户支持技术人员与英特尔公司签订合同
以上来自于谷歌翻译 以下为原文 Hello Punga, Were you able to follow the steps provided above? Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-24 16:41 , Processed in 0.559555 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
