我正在尝试解决我的Veeam服务器的问题。
其中一个故障排除提示是禁用TCP Checksum Offload。 当我尝试禁用然后选择确定以关闭X710属性框时,我收到错误“SetSetting failed”这是一个Server 2016框,更具体地说,我正在尝试禁用以下设置。 IPv4校验和OffloadLarge接收OffloadLarge发送OffloadTCP校验和卸载 但正如所述,当我选择OK,然后确定关闭属性框我多次得到SetSetting失败错误.X710 以上来自于谷歌翻译 以下为原文 I'm trying to troubleshoot problems with my Veeam server. One of the troubleshooting tips is to disable TCP Checksum Offload. When I try to disable and then choose Ok to close the X710 properties box I get an Error "SetSetting failed" This is a Server 2016 box, and to be more specific, I'm trying to disable the following settings.
But as stated, when I choose OK, then OK to the close the Properties box i get the SetSetting failed error several times.X710 |
6个回答
您好tcolquette,感谢您在英特尔有线社区中发帖。为了让我们更好地为您提供帮助,请提供有关您的设置的其他信息。
X710的标记。 这可以在物理网络适配器2上的白色标签中找到。 驱动版本已加载3。 诊断测试的结果。 “诊断”位于X710属性的“链接速度”选项卡中。向前看您的回复。最好的问候,Vince T.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hi tcolquette, Thank you for posting in Intel Wired Communities. In order for us to better assist you, please provide additional information regarding your setup. 1. Markings of the X710. This can be found in the white sticker on the physical Network Adapter. 2. Driver version loaded 3. Result of the diagnostics test. The "Diagnostics" is located in the "Link Speed" tab of the X710 properties. Looking forward to your response. Best regards, Vince T. Intel Customer Support |
jerry1978 发表于 2018-11-7 10:29 不幸的是,我没有物理访问它,因为它在另一个办公室。 它是直接iSCSI通过IP地址连接到ESXi主机而没有网关,因此诊断程序无法查看任何DNS,网关,DHCP等。有关1ms的回复,将该端口ping到直连端口。 x710正在运行驱动程序23.2.0.1006。 我能够运行Powershell命令来禁用TCP Checksum Offload(IPv4),但不能执行任何其他需要的选项。 以上来自于谷歌翻译 以下为原文 Unfortunately, I do not have physical access to it as it's in another office. It is direct iSCSI connected to a ESXi host via IP Address with no gateway so the Diagnostics are unable to see any DNS, Gateway, DHCP, etc. There is 1ms reply on pinging out that port to the direct connected port. The x710 is running driver 23.2.0.1006. I was able to run a Powershell command to disable the TCP Checksum Offload (IPv4), but not any of the other needed options. |
cd340823 发表于 2018-11-7 10:46 嗨tcolquette,请分享用于关闭其他所需选项的Powershell命令。 您是否尝试过下面的RegistryKeyword?适配器选项RegistryKeywordChecksum Offload for IPv4 * IPChecksumOffloadIPv4Large send offload for IPv4 * LsoV2IPv4Receive segment coalescing for IPv4 * RscIPv4Best问候,Vince T.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hi tcolquette, Please share the Powershell command used to turn off the other needed options. Have you tried the RegistryKeyword below? Adapter option RegistryKeyword Checksum Offload for IPv4 *IPChecksumOffloadIPv4 Large send offload for IPv4 *LsoV2IPv4 Receive segment coalescing for IPv4 *RscIPv4 Best regards, Vince T. Intel Customer Support |
jerry1978 发表于 2018-11-7 11:01 您好tcolquette,如果您能够根据提供的注册表关键字修改选项,请告诉我们。请转到您的回复。最诚挚的问候,Vince T.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hi tcolquette, Please let us know if you were able to modify the options based on the provided Registry keywords. Looking forward to your response. Best Regards, Vince T. Intel Customer Support |
60user31 发表于 2018-11-7 11:20 您好tcolquette,如果您仍然需要有关您的问题的帮助,请告诉我们。 如果X710已集成到您的系统中,您也可以与计算机制造商联系以获得进一步的支持。最诚挚的问候,Vince T.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hi tcolquette, Please let us know if you still need assistance regarding your issue. If the X710 is integrated to your system, you may also get in touch with the computer manufacturer for further support. Best Regards, Vince T. Intel Customer Support |
jerry1978 发表于 2018-11-7 11:30 您好tcolquette,我们想检查您是否有其他需要英特尔有线社区的帮助。 谢谢。最诚挚的问候,Vince T.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hi tcolquette, We'd like to check if you have other assistance needed from Intel Wired Communities. Thanks. Best Regards, Vince T. Intel Customer Support |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 14:36 , Processed in 0.623788 second(s), Total 76, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
