大家好,这里的总菜鸟。
我正在研究我们开发的测试系统,以测试电力变压器的电流比。 我们有一个工作计划,一切正常,所以我正在努力准备系统,以便在我们的生产车间使用。 我宁愿保持主程序(.Vee)安全,所以我想将它转换为运行时文件(.vxe)我经历了一个安全的vxe步骤,它正常工作,当我打开vxe它开始运行 测试。 测试完成后,单击“确定”,程序将关闭。 是否可以使程序保持打开状态,这样我就可以测试多个变换器而无需每次都重新打开文件? 如果不是,我最好的选择就是让员工在地板上使用vee文件,并确保我将某个副本保存在安全的地方? 谢谢尼克 以上来自于谷歌翻译 以下为原文 Hello everyone, Total noob here. I am working on a testing system we developed in order to test current ratios for electrical transformers. We have a working program and everything is working properly so I am trying to prepare the system for use on our production floor. I would prefer to keep the main program (.Vee) safe so I want to convert it to a runtime file (.vxe) I went through the steps to make a secured vxe and it works properly, when I open the vxe it starts running the testing. When the testing is done I click OK and the program closes. Is it possible to make the program stay open so I can test multiple transformers without having to re open the file every time? If not would my best option be to just let the employees use the vee file on the floor and just make sure I have a copy saved somewhere safe? Thanks Nick |
3个回答
听起来像一个有趣的应用程序;-)当您的VEE程序完成/停止时,这是vxe退出时的解决方案是保持程序运行。
作为一个简单的例子(在文本中!我可以附加一个VEE示例,如果它不清楚)直到Break [流程 - >重复对象] --->你的程序代码--->确定/测试下一个[按钮]将停在 确定按钮(因为它听起来像你现在一样,可能显示结果),然后在按OK后开始。 通常,您可能在直到中断之前有一个“初始化”块,只需要在开始时运行一次。 然后你添加第二个OK按钮(没有附加到其他任何东西),重命名为Close或Quit或任何你喜欢的:关闭[重命名的OK按钮] --->停止[Flow - > Stop object]显然必须添加关闭按钮 到您的用户面板。 当测试足够的变压器时,这将关闭vxe。 以上来自于谷歌翻译 以下为原文 Sounds like an interesting application ;-) When your VEE program finishes / stops, that's when the vxe exits so the solution is to keep the program running. As a simple example ( in text! I can attach a VEE example if it's not clear ) Until Break[Flow -> Repeat object] ---> your program code ---> OK/test next[button] that will stop at the OK button ( as it sounds like you have at the moment, probably to show the results ) and then start at the beginning after you press OK. Typically you might have an 'initialisation' block before the Until Break that only needs to be run once at the start. Then you add a second OK button ( not attached to anything else ), rename it Close or Quit or whatever you prefer: Close[renamed OK button] ---> Stop[Flow -> Stop object] Obviously the Close button must be added to your user panel. This will close the vxe when enough transformers have been tested. |
尼克,你必须为该程序添加一个Until Break循环,以便不再退出它而只是重新开始。
在开始按钮后立即放置。 -法案 以上来自于谷歌翻译 以下为原文 Nick, you have to add an Until Break loop to that program so that intead of exiting it just starts again. Put it right after the start button. -Bill |
真棒!
谢谢你的帮助。 我将研究直到中断循环。 非常感谢你! 缺口 以上来自于谷歌翻译 以下为原文 Awesome! Thanks for the help guys. I'll look into that Until break loop. Thank you very much! Nick |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1855 浏览 1 评论
1714 浏览 5 评论
2581 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 21:06 , Processed in 0.996813 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
