你好,先生,现在我使用PSoC3控制器(CY8C446AXI—099)。我做了一个最终的硬件,在这个过程中,我附加了控制器所需要的一些部件。但是,那个控制器没有被适当地供电,它持续发光的功率。我们在硬件中发现了一个错误,VCCA是由5伏供电,所以对于这个错误,一个控制器烧毁,但之后,我断开5个伏在其他硬件和新的控制器,并附加1UF上限由一个外部跳线。我可以只喜欢这一个错误,而不是这个没有任何错误。成立。在此之后,我将直接5伏电源连接到控制器,测量电源两端的电压,然后电压从5伏下降,并不断变化。我附上基于此的视频供您参考。我在Vcc附加470UF 25伏盖和0.1旁路帽的控制器的GND。并将所有的0.1UF和1UF盖按要求安装在控制器中。另外,请附上我正在使用的控制器示意图。请回顾一下示意图。如果我犯了错误,就纠正我。
以上来自于百度翻译 以下为原文 Hello sir Now a days I am Using psoc3 controller ( cy8c3446AXI - 099 ). I Made a Final Hardware and in that, I attach some component which is required for a controller . but rather then that controller is not powered up properly its continuously shining power. we found one bug in hardware that VCCA is power up by 5 volts so for that error, one controller burns out but after that now I disconnect the 5 volts in other hardware & new controller and attach 1uF cap by an external jumper wire.I can just fond this one error rather than this no any error is being founded. after this I attach the Directly 5-volt power supply to the controller and measuring the voltage across the supply then voltage being down from 5 volts and continuously changing. I attach the video based on that for your reference. I attach 470uF 25-volt cap in Vcc and GND of a controller with 0.1 bypass cap. and also attach all the 0.1uF and 1uF cap as required in a controller. also, attach the controller schematic which I am using. please review that schematic. and correct me if I did any mistake in that |
1个回答
你好,Brijesh,
电源连接请参阅本页的第3-3页。 HTTP://www. CyPress .COM/FIL/445 81/A下载 这将是有益的。 这条线没有附图,请附上示意图。 谢谢, 安克斯 以上来自于百度翻译 以下为原文 Hello Brijesh, For power connection please refer to page#3-4 of this AN- http://www.cypress.com/file/44581/download It will be helpful. No schematic is attached with this thread.Please attach the schematic. Thanks, ANKS |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-18 17:42 , Processed in 0.668609 second(s), Total 72, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
