能不能像eCap那样捕捉一个边沿,然后保持住边沿时刻?
因为我看user manual中对HRCAP讲得很初略,其中说,HRCAP的counter会在任何一个边沿跳变的时候就归零,这样就没办法测量经过n个脉冲后的时间了吧? 不知道我有没有说清楚,谢谢专家解答! |
1 条评论
1 个讨论
您说的是F2806x么?你的理解是对的,这和eCAP是不一样的。
When a rising edge is detected, the value in HCCOUNTER is captured into the 16-bit HCCAPCNTRISE0 register before the counter resets to 0. When a falling edge is detected, the value in HCCOUNTER is captured into the 16-bit HCCAPCNTFALL0 register before the counter resets to 0. The HRCAP capture registers include a 2-deep FIFO buffer to store two pulse widths’ worth of data. When a rising edge event occurs, HCCAPCNTRISE0 is loaded with the pulse width data from the last falling edge to the current rising edge (low pulse width). At the next rising edge event, the value in the HCCAPCNTRISE0 register is loaded into HCCAPCNTRISE1. When a falling edge event occurs, HCCAPCNTFALL0 is loaded with the pulse width data from the last rising edge to the current falling edge (high pulse width). For falling edge events, the HRCAP logic operates such that the HCCAPCNTFALL0 register value is then loaded into the HCCAPCNTFALL1 register at the next rising edge event rather than waiting until the next falling edge event. 如果您认为此问题已被解答,请在“这是否解答您的问题” 后,点击“是”按钮! 谢谢您的合作! |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9351 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-18 03:19 , Processed in 0.513840 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
