大家好,
我有一个小的Vivado项目,想要修复整个设计的路由。 然后,我想将某些单元移动到FPGA架构的其他区域,同时保留剩余的布线。 我想知道如何通过Vivado实现这一目标? 谢谢 以上来自于谷歌翻译 以下为原文 Hello all, I have a small Vivado project and want to fix the routing for the entire design. I then want to move certain cells to other regions of the FPGA fabric, while preserving the remaining routing. I am wondering how this can be accomplished with Vivado? Thanks |
6个回答
我应该注意到我已经尝试修复每个网络的路由,这会生成FIXED_ROUTE,BEL和LOC约束。
此外,我确保在这样做时修复称重传感器引脚。 但是,如果没有驱动程序,我会收到严重警告。 谢谢 以上来自于谷歌翻译 以下为原文 I should note that I have tried fixing the routing for each net, which generates a FIXED_ROUTE, BEL, and LOC constraints. Additionally, I make certain to fix the load cell pins when doing so. However, I receive a critical warning when doing so that there is no driver. Thanks |
嗨@rfuller
您可以使用增量编译流程。 https://www.xilinx.com/support/answers/57853.html 有关详细信息,请参阅https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf的第90页。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @rfuller You can use incremental compile flow. https://www.xilinx.com/support/answers/57853.html Refer to page 90 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf for details. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
@rfuller你试过route_design,再次移动cell和route_design吗?
route_design做了一个rip& 仅针对更改重新路由。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 @rfuller have you tried route_design, move cell and route_design again? route_design does a rip & re-route only for changes. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
Vijayak和Muzaffer,
谢谢您的回复。 一旦我做了route_design,有没有办法验证路由没有改变? 例如,Vivado生成的文件是否包含可读格式的完整路由信息? 谢谢 瑞安 以上来自于谷歌翻译 以下为原文 Vijayak and Muzaffer, Thank you for your replies. Is there any way to verify the routing has not changed once I do a route_design? For example, is there a file generated by Vivado that contains the complete routing information in a readable format? Thanks Ryan |
为了生成路由列表,我使用了以下TCL命令:
set fp [open w] set all_nets [get_nets -hierarchical] puts $ fp“$ all_nets”close $ fp set fp [open w] set all_route [get_property ROUTE [get_nets -hierarchical]] put $ fp“$ all_route”close $ fp 我希望这会将所有网络列表和路由信息写入两个单独的文件。 然后我将文本文件拉入Matlab并将它们与其他版本的文件进行比较。 我的问题是,这实际上是否会生成所有网络的路由列表? 谢谢 以上来自于谷歌翻译 以下为原文 In order to generate a routing list, I used the following TCL commands: set fp [open set all_nets [get_nets -hierarchical] puts $fp "$all_nets" close $fp set fp [open set all_route [get_property ROUTE [get_nets -hierarchical]] puts $fp "$all_route" close $fp I am hoping this will write a list of ALL nets and routing information to two separate files. I then pull the text files into Matlab and compare them to files for other versions. My question is, will this actually generate a list of the routes for ALL nets? Thanks |
嗨@ vijayak,
谢谢你的建议。 使用增量编译流程以及以下TCL命令,我能够修复所有网络的路由,除了那些连接到正在移动的单元格的网络: lock_design -level routing 我还可以通过重用报告以及TCL脚本确认路由没有改变 - 除了移动的单元格。 再次感谢。 瑞安 以上来自于谷歌翻译 以下为原文 Hi @vijayak, Thank you for your suggestion. Using the incremental compile flow, as well as the following TCL command I was able to fix routing for all nets except those attached to the cells being moved: lock_design -level routing I could also confirm with the reuse report, as well as TCL scripts, that the routing had not changed--except for the cells that were moved. Thanks again. Ryan |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 12:13 , Processed in 0.906765 second(s), Total 47, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
