我遇到了L6472当前规定的问题。我们制作了2个系列的电路板,一个配有L6474,另一个配有L6472。该板有8个通道,供电电压为24V / 3.3V,定时参数默认复位,内部振荡器。电机绕组有1.7欧姆,3.6mH。该板有4层35 m,包括24V和GND的实心平面。 L6474的一切都很好。利用L6472,相电流急剧地接近微步序列的过零点。所有通道都受到影响,但通常只有每个通道的一个相位。预测和峰值电流调节之间没有区别。我有几个想法可能是错的:
1)电流测量受一些地移效应的影响 2)电源电压太嘈杂 3)次优时序参数 我想知道在哪里先看。 #l6472-current-regulation#l6472-l6474-current-regulation 以上来自于谷歌翻译 以下为原文 I am experiencing problem with the current regulation of the L6472. We made 2 series of boards, one was fitted with L6474s, the other one with L6472s. The board has 8 channels, supply voltage is 24V / 3.3V, timing parameters are reset default, internal oscillator. The motor windings have 1.7Ohm, 3.6mH. The board has 4 layers of 35�m including solid planes for 24V and GND. Everything is fine for the L6474. With the L6472 the phase current jumps wildly close to the zero crossing of the microstep sequence. All channels are affected, but usually only one phase of each channel. No difference between predictive and peak current regulation. I have several ideas what could be wrong: 1) Current measurement influenced by some ground shift effect 2) Supply voltage too noisy 3) Suboptimal timing parameters I am wondering where to look first. #l6472-current-regulation #l6472-l6474-current-regulation |
2个回答
你好,
这似乎是对电流感测电路的抵消效应。 您可以尝试以下解决方案: - 略微增加目标电流,这样传感电路应该更好地工作 - 减少快速衰减持续时间(快速衰减导致系统失控) - 降低压摆率 顺便说一下,你当前的控制设置是什么(快速衰减,最短时间,tsw等)? 问候 恩里科 以上来自于谷歌翻译 以下为原文 Hello, This seems to be an offset effect on the current sensing circuitry. You can try the following solutions: - slightly increase the target current, this way the sensing circuitry should work better - decrease the fast decay duration (the fast decay causes the system to go out of control) - decrease the slew rate By the way, what is your current control setup (fast decay, minimum on time, tsw, etc.)? Regards Enrico |
我有类似的问题。我们遇到了IC过热的问题,因此我提高了压摆率并且有所帮助。但现在,我们看到随机过电流,我想知道单独降低快速衰减持续时间是否足够。我们有3个3欧姆/ 3mH范围的电机,我目前的参数是推荐用于L6472评估板的:
POW_SR = 00 ton_min = 4us toff_min = 21us toff_fast = 10us fast_step = 16us tsw = 48us 我尝试将fast_step放到10us,它似乎工作正常,但错误是间歇性的,我想有一些余地。有什么建议么? 此外,我想知道你是否可以解释为什么调整SR或快速衰减有帮助。 以上来自于谷歌翻译 以下为原文 I'm having a similar issue. We had problems with overheating of the IC, so I increased the slew rate and that helped. But now, we're seeing random over-currents and am wondering if dropping the fast decay duration alone will be enough. We have several motors in the 3 ohm/ 3mH range, My current parameters are what was recommended for the L6472 Eval board: POW_SR = 00 ton_min = 4us toff_min = 21us toff_fast = 10us fast_step = 16us tsw = 48us I tried dropping fast_step to 10us, and it seems to work ok, but the error is intermittent, and I'd like to have some margin. Any suggestions? Also, I wonder if you can explain why adjusting the SR or fast decay helps. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
552浏览 3评论
479浏览 3评论
GMT+8, 2024-4-19 21:00 , Processed in 0.660846 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
