我有一个固定的堆栈引导加载程序,我建立,但不时,想更新配置文件。我不需要更新BLE堆栈,所以实现升级包的内存价格太高了。我只想能够将自定义属性/特性添加到现有的配置文件中。我的想法是,在BootloadDead应用程序中,我可以用一个配置文件只使用BLE组件,然后在引导加载时将它转换到Bootloader版本中。
以上来自于百度翻译 以下为原文 I have a fixed stack bootloader application that I built, but from time to time, would like to update the profile. I don't really need to update the BLE stack, so the memory price to implement a upgradeable stack is too high. I simply want to be able to add custom attributes/characteristics to the existing profile. My thought was that I could do that with a profile only BLE component in the bootloadable application and swap it in over the bootloader version when the bootloadable gets loaded? |
4个回答
Irc,有一个帖子问了一个类似的问题(切换BLE配置文件),我想说结论是否定的。没有办法动态地切换配置文件;但是,我不确定…
以上来自于百度翻译 以下为原文 Iirc, there was a post asking a similar question (switching BLE profiles), and I want to say that the conclusion was no. There is no way to switch the profiles dynamically on the fly; But, I don't know for sure... |
嗯,我没有看到帖子在我的搜索。我试着再挖一些。肯定会很方便的!这似乎是一件合理的事。 以上来自于百度翻译 以下为原文 Hmm, I did not see the post come up in my search. I'll try and dig some more. It sure would be handy!! And it seems like a reasonable thing to do. |
多亏了你的指导,我找到了“支持两个配置文件”,但它没有给出任何关于如何真正做到这一点的讨论。有什么想法吗? 以上来自于百度翻译 以下为原文 Thanks to your guidance, I was able to find this "Supporting two profiles BLE", but it does not give any discussion about how to actually do it. Any ideas? |
我找到了我在这里提到的相关线程:RE:支持多个配置文件? 不幸的是,答案是否定的。 理论上,您可以实现配置文件,然后只使用应用程序代码对配置文件服务值/属性进行操作,这将允许您更新应用程序代码中如何处理值/属性,但这将违背将数据分离为个性化的目的。铝服务… 以上来自于百度翻译 以下为原文 I found the relevant thread that I was referring to here: Re: Multiple profiles, supported? The answer is no unfortunately. Theoretically, you could implement a profile, and then just operate on the profile service values/attributes with application code, which would allow you to update how the values/attributes are handled in the application code, but that would defeat the purpose of having data separated into individual services... |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1637 浏览 1 评论
3392 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
323浏览 1评论
45浏览 1评论
GMT+8, 2024-3-29 07:13 , Processed in 0.563256 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
