您好,如果我想为我的设计获得最佳时序收敛,我应该使用什么实施策略?
例如,如果我想改善设置和保持的松弛度,我应该选择哪种最佳策略? 以上来自于谷歌翻译 以下为原文 Hello, If i want to get a best timing closure for my design, what implementation strategy should I use? For example, if i want to improve the slack for both setup and hold, what is the best strategy I should choose? |
3个回答
HI @ softwind555,
请查看此类似帖子: https://forums.xilinx.com/t5/Timing-Analysis/timing-closure-with-implementation-strategies/td-p/533267 谢谢& 问候, Sravanthi B -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 HI @softwind555, Please check this similar post : https://forums.xilinx.com/t5/Timing-Analysis/timing-closure-with-implementation-strategies/td-p/533267 Thanks & Regards, Sravanthi B ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- View solution in original post |
HI @ softwind555,
请查看此类似帖子: https://forums.xilinx.com/t5/Timing-Analysis/timing-closure-with-implementation-strategies/td-p/533267 谢谢& 问候, Sravanthi B -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- 以上来自于谷歌翻译 以下为原文 HI @softwind555, Please check this similar post : https://forums.xilinx.com/t5/Timing-Analysis/timing-closure-with-implementation-strategies/td-p/533267 Thanks & Regards, Sravanthi B ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
@ softwind555in那个列表我的选择将是“explorepostroutephysopt”。
我有一个自定义脚本,它执行了许多“route_design -tns”和phys_opt_design,它提供了与该流程类似的非常好的结果。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 @softwind555 in that list my choice would be "explorepostroutephysopt". I have a custom script which does a number of "route_design -tns" and phys_opt_design which gives really good results which is similar to that flow. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 08:12 , Processed in 1.017991 second(s), Total 72, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
