扫一扫,分享给好友
电路是没问题的,蜂鸣器和LED彩灯单独是都可以工作,,,电路图挺简单的,就几个接口,看程序应该知道了,希望大家帮帮忙呗,谢谢!!!!
程序:#include #include #define uint unsigned int #define uchar unsigned char #define LED0 P0 #define LED2 P2 uchar code water_led1[] = {0XFE,0XFD,0XFB,0XF7,0XEF,0XDF,0XBF,0X7F};//正向流动 uchar code water_led2[] = {0X7F,0XBF,0XDF,0XEF,0XF7,0XFB,0XFD,0XFE};//反向流动 ***it Buzz = P1^7; //声明绑定蜂鸣器 unsigned int code NoteFrequ[]= { 523,587,659,698,784,880,988, //中音对应的1-7 1047,1175,1319,1397,1568,1760,1976 //高音对应的1-7 }; unsigned int code NoteReload[]= //中音1-7和高音1-7对应的定时器重载值 { 65536 - (11059200/12) /(523*2),//中音1-7 65536 - (11059200/12) /(587*2), 65536 - (11059200/12) /(659*2), 65536 - (11059200/12) /(698*2), 65536 - (11059200/12) /(784*2), 65536 - (11059200/12) /(880*2), 65536 - (11059200/12) /(988*2), 65536 - (11059200/12) /(1047*2),//高音1-7 65536 - (11059200/12) /(1175*2), 65536 - (11059200/12) /(1319*2), 65536 - (11059200/12) /(1397*2), 65536 - (11059200/12) /(1568*2), 65536 - (11059200/12) /(1760*2), 65536 - (11059200/12) /(1970*2) }; bit enable = 1; //发声使能标志 bit tmrflay = 0; //定时器 中断完成标志 unsigned char T0RH = 0xff; //T0重载值高字节 unsigned char T0RL = 0x00; //T0重载值低字节 void PlayTwotiger(); void main() { uint j = 0; uint count = 0; unsigned int i; EA = 1; TMOD =0x11; //模式1 TH0 = T0RH; TL0 = T0RL; ET0 = 1; //使能T0中断 TR0 = 1; //启动 TH1 = 0XF8; TL1 = 0X43; TR1 = 1;//启动T1 while(1) { if (TF1 == 1)//判断TF0是否溢出 { TF1 = 0;//T1溢出后,清零 TH1 = 0XF8; //B8; TL1 = 0X43; //ef; count ++; if (count == 100)//计数 { count = 0; if ( j < 8 && j>=0 ) LED0 = water_led1[j]; if ( j >= 8 && j < 16) { LED0 = 0XFF; LED2 = water_led1[j - 8 ]; } if ( j == 17 ) LED2 = 0XFF; if ( j >= 18 && j < 26) LED2 = water_led2[j - 18 ]; if ( j >= 26 && j < 34) { LED2 = 0XFF; LED0 = water_led2[j - 26 ]; } if ( j >= 34 && j < 42 ) { LED0 = 0XCC; LED2 = 0XCC; } if ( j >= 42 && j < 50 ) { LED0 = 0X33; LED2 = 0X33; } if ( j >= 50 && j < 58 ) { LED0 = water_led1[j - 50]; LED2 = water_led2[j - 50]; } if ( j >= 58 && j < 66 ) { LED0 = water_led2[j - 58]; LED2 = water_led1[j - 58]; } if ( j >= 66 && j < 68) { LED0 = 0XFF; LED2 = 0XFF; } if ( j >= 68 && j < 72) { LED0 = 0X00; LED2 = 0X00; } if ( j >= 72 && j < 74) { LED0 = 0XFF; LED2 = 0XFF; } if ( j >= 74 && j < 76) { LED0 = 0XFF; LED2 = 0XFF; } if ( j >= 76 && j < 80) { LED0 = 0X00; LED2 = 0X00; } if ( j >= 80 && j < 82) { LED0 = 0XFF; LED2 = 0XFF; } j ++; if ( j == 82) j = 0; } } PlayTwoTiger(); for(i=0;i<40000;i++); } } /**音乐函数**/ void PlayTwoTiger() { unsigned char beat; //节拍索引 unsigned char note; //节拍对应音符 unsigned int time=0; //节拍计时 unsigned int beattime=0; //总时间计时 unsigned int soundtime=0; //没拍发声时间 unsigned char code PlayTwoTigerNote[]= //音符表 { 1,2,3,1, 1,2,3,1, 3,4,5, 3,4,5, 5,6,5,4,3,1, 5,6,5,4,3,1, 2,1,4, 2,1,4 // 3,1,4, 3,1,4 // 1,5,1, 1,5,1 }; unsigned char code PlayTwoBeat[]= //节拍表,4表示一拍,1表示1/4拍,8表示两拍 { 4,4,4,4, 4,4,4,4, 4,4,8, 4,4,8, 3,1,3,1,4,4, 3,1,3,1,4,4, 4,4,8, 4,4,8, }; for(beat=0; beat { while(!tmrflay); //每次定时器中断完成 节拍处理 tmrflay = 0; if(time == 0) //节拍播放完成重启 { note = PlayTwoTigerNote[beat]-1; T0RH = NoteReload[note]>>8; T0RL = NoteReload[note]; //计算总时间,右移2位等于除4,移位代替除法加快速度 beattime = (PlayTwoBeat[beat]*NoteFrequ[note]) >>2; //计算发声时间,为总时间的0.75s soundtime =beattime - (beattime>>2); enable = 1; //开始发声 time++; } else //节拍播放未结束则继续处理 { if(time >= beattime) //当前时间清零 { time = 0; //准备重新启动 beat++; } else //累加时间 { time++; if(time == soundtime) //发声时间到达,关闭蜂鸣器 { enable =0; //用以区分连续两个节拍 } } } } } void InterRupt() interrupt 1 //中断服务 { TH0 =T0RH; TL0 =T0RL; tmrflay = 1; if(enable){ Buzz=~Buzz; }else{ Buzz=1; } } |
4个回答
感觉像是一个中断启动后,去中断另一个中断运行的内容。这连个中断按要求应该不是互相独立的,应该是互相依存的关系。
1 条评论
同意楼上坛友的见解
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
551 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
853 浏览 0 评论
2529 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2268 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1708 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5781 浏览 31 评论
GMT+8, 2024-4-24 21:32 , Processed in 0.584764 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
