大家好,我这里有一个简单的代码。我要读无符号char UART1YRX缓冲器[80 ],缓冲器从0x9EC开始,它是:在这里我的函数读取缓冲器,在这里我称为WIT-PTR值0x9ED:为什么工作而不是???????
以上来自于百度翻译 以下为原文 Hi to all, I have here simple piece of code. I'm going to read unsigned char UART1_RxBuffer[80], buffer starts at 0x9EC and it is: 0x9EC -> 0x52 (Start header char) 0x9ED -> 0x03 (Header type) 0x9EE -> 0x03 (Number of bytes LSB) 0x9EF -> 0x00 (Number of bytes MSB) 0x9F0 -> 0x01 (message byte 1) 0x9F1 -> 0x00 (message byte 2) 0x9F2 -> 0x00 (message byte 3) 0x9F3 -> 0x04 (checksum LSB) 0x9F4 -> 0x12 (checksum MSB) Here my function to read buffer where I call wit ptr value 0x9ED: void ManageHeaderType (unsigned char *ptr) { unsigned char *ptr_chk, *dummy_ptr; unsigned char HdrType; unsigned int l_NumOfBytes; unsigned char CK_A, CK_B = 0; unsigned int i, CheckSum; unsigned int *int_ptr; unsigned int brody; ptr_chk = ptr; HdrType = *ptr++; // it correctly reads 0x03 // reading unsigned int using unsigned char pointer l_NumOfBytes = *(unsigned int *)(ptr); // it correctly reads 0x0003 dummy_ptr = ptr; dummy_ptr += l_NumOfBytes+2; // ptr value is 0x9F3 int_ptr = (unsigned int *)dummy_ptr; // int_ptr value is 0x9F3, MPLAB X correctly shows *int_ptr = 0x1204 in tooltip CheckSum = *(unsigned int *)(dummy_ptr); // now CheckSum contents is 0x09F3 brody = *int_ptr; // here value of brody is 0x09F3 Why l_NumOfBytes = *(unsigned int *)(ptr); works while CheckSum = *(unsigned int *)(dummy_ptr); and brody = *int_ptr; not????? |
1个回答
OK -不应该是这样的,但是-IIr- 16位PICS希望整数驻留在偶数地址上(9F3是奇数!)这可能是造成这种不良行为的原因。我希望得到更好的结果微笑:
以上来自于百度翻译 以下为原文 OK - shouldn't be like that. But - IIRC - the 16-Bit PICs expect integers to reside on even addresses (9F3 is odd!) - which might be a reason for this mi***ehavior. I'd expect CheckSum = *dummy_ptr + (*(dummy_ptr+1) << 8); to yield better results Smile: |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
363浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1799浏览 0评论
GMT+8, 2024-4-25 00:13 , Processed in 1.150086 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
