你好。我已经订购了PSoC 5 M/C(CY8C588LTQ-LP097)。我想把它安装到一个PCB的“通孔”格式-有一个IC适配器,可以使芯片从QFN类型到通孔形式?
我一直找不到任何合适的IC适配器在线。 将不胜感激! 以上来自于百度翻译 以下为原文 Hi. I have ordered a PSoC 5 M/C (CY8C5888LTQ-LP097). I'm looking to mount this to a pcb in "through hole" format - is there an IC adapter which could adapt the chip from its QFN type to through hole form? I've been unable to find any suitable IC adapter online.. Would greatly appreciate any help! |
4个回答
WA13081DQAETRAC温斯洛直通孔安装0.5毫米,2.54毫米间距IC插座适配器,68针女性QFN到68π…
? 以上来自于百度翻译 以下为原文 WA13081DQAETRC | Winslow Straight Through Hole Mount 0.5 mm, 2.54 mm Pitch IC Socket Adapter, 68 Pin Female QFN to 68 Pi… ? |
非常感谢保罗,看起来这将做得很好-非常感谢你的帮助!我搜查过,但确实发现了… 再次感谢! 以上来自于百度翻译 以下为原文 Thanks very much Paul, looks like that will do the job perfectly - really appreciate your help! I had searched RS but did find that.. thanks again! |
嗨,保罗, 原来,适配器是一个更大尺寸的封装(10×10 QFN 68引脚),其中PSoC 5(CY8C588LTQ-LP097),我正在寻找安装是8×8大小。 似乎没有想到,同样的制造商,WimSalpAdvices,有一个合适的适配器。 如果有其他的建议,我会非常感激他们… 谢谢, 约翰 以上来自于百度翻译 以下为原文 Hi Paul, Turns out that adapter was for a larger size of package (10 x 10 QFN 68pin) wheras the PSoC 5 (CY8C5888LTQ-LP097) I'm looking to mount is 8 x 8 size. Doesn't appear as thought the same manufacturers, WinslowAdaptics, have a suitable adapter. If there are any other suggestions out there I'd greatly appreciate them... Thanks, John |
testd27 发表于 2018-11-2 19:25 好吧,如果是中型到大型生产,我会说订购一些从在线服务,使PCB从鹰CAD等文件。 对于一个或一对夫妇,假设您有空间,我会购买CY8CKIT-059,从CY588侧断开,如果需要的话,去掉LED,以及用于SAR和CMOD的CAPS,并添加头使其成为DIP模块。 以上来自于百度翻译 以下为原文 Well, if it's for medium to large production, I would say to order some from one of the online services that makes PCBs from Eagle CAD, etc, files. For one or a couple, assuming you have room for it, I would buy the CY8CKIT-059, snap off the CY5888 side, if needed, remove the LED, and the caps used for SAR and CMOD, and add headers to make it into a DIP module. |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1637 浏览 1 评论
3392 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
323浏览 1评论
45浏览 1评论
GMT+8, 2024-3-28 22:28 , Processed in 0.717019 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
