问候,
两个与ODDR相关的问题: 1)如果我想将由同一个BUFG驱动的同一时钟转发到多个外部设备,我是否必须实例化几个ODDR? 或者,如果我只是实例化一个ODDR并将输出驱动到指向外部设备的多个OBUF,Vivado会将几个ODDR推断到输出缓冲区的I / O块中? 2)在他/她的FPGA中可以使用多少ODDR? 根据我的理解,如果ODDR确实在I / O块中实例化(我在下面的附件中圈出的那个,我就是......?),那么就会有许多ODDR可用作FPGA引脚......正确 ? 干杯! 以上来自于谷歌翻译 以下为原文 Greetings, Two ODDR-related questions: 1)If I want to forward the same clock, driven by the same BUFG, to multiple external devices, do I have to instantiate several ODDRs? Or if I just instantiate one ODDR and drive its output to multiple OBUFs pointing to the external devices, Vivado will infer several ODDRs into the I/O blocks of the output buffers? 2)Is there a limit on how many ODDRs one can use in his/her FPGA? From my understanding, if an ODDR is indeed instantiated in an I/O block (which is the one I have circled in the attachment below I persume..?), then there would be as many ODDRs available as the FPGA pins...correct? Cheers! |
4个回答
是的
2.每个IOB都具有ODDR功能 确保检查具有许多此类接口的信号完整性(驱动器不超过同时切换输出限制 - SSO)。 Austin Lesea主要工程师Xilinx San Jose 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 1. Yes 2. Every IOB has ODDR capability Be sure you check the signal integrity of having many such interfaces (drivers do not exceed simultaneous switching outputs limits - SSO). Austin Lesea Principal Engineer Xilinx San JoseView solution in original post |
是的
2.每个IOB都具有ODDR功能 确保检查具有许多此类接口的信号完整性(驱动器不超过同时切换输出限制 - SSO)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 1. Yes 2. Every IOB has ODDR capability Be sure you check the signal integrity of having many such interfaces (drivers do not exceed simultaneous switching outputs limits - SSO). Austin Lesea Principal Engineer Xilinx San Jose |
@austin感谢你的回复!
所以我想多个ODDR是要走的路...... 你究竟是什么意思: 确保检查具有许多此类接口的信号完整性(驱动器不超过同时切换输出限制 - SSO)。你的意思是BUFG不应该驱动许多输出引脚吗?干杯 以上来自于谷歌翻译 以下为原文 @austin Thanks for the reply! So I guess that multiple ODDRs is the way to go... What exactly do you mean by the: Be sure you check the signal integrity of having many such interfaces (drivers do not exceed simultaneous switching outputs limits - SSO). Do you mean that a BUFG shouldn't be driving many output pins? Cheers |
你究竟是什么意思:
确保检查具有许多此类接口的信号完整性(驱动器不超过同时切换输出限制 - SSO)。 当输出缓冲器进行转换时,它从VCCO轨引出电流或通过驱动晶体管将电流吸收到GND。 这些过渡会产生瞬间的电流尖峰。 如果太多的高驱动输出同时进行转换,这些电流尖峰会组合并导致VCCO(称为“下垂”)或GND(称为“接地反弹”)的瞬间中断。 这些的净效应是输出本身可能比预期的转变慢,甚至相邻的信号也会显示出一些中断(即使它们没有转换)。 这称为“同时开关噪声(SSN)”或“同时切换输出(SSO)”的问题。 在一组I / O中,在我们开始看到损坏之前,可以容忍最大数量的SSO。 这取决于(非常高!)I / O标准,驱动强度和转换速率。 它还取决于信号“同时”切换的方式; 即使两个输出切换之间的1ns偏差也足以使它们不被视为“同时”。 通过在同一时钟上使用IOB触发器,我们有意使信号“尽可能同时”。 当我们驱逐时钟时,我们知道每个时钟在每个时钟周期转换两次。 因此,SSN成为一个问题。 但是,它再次高度依赖于I / O标准 - 例如对于具有16mA驱动和快速转换的LVCMOS33,SSO的最大数量非常小 - 远低于存储体中的引脚数。 但是,在慢转换速率下,您几乎可以同时切换所有引脚,没有任何问题。 Vivado(和ISE)有用于验证SSO的设计规则检查 - 在Vivado中它被称为SSN,在ISE中它被称为WASSO(加权平均SSO)。 一定要查看这些...... Avrum 以上来自于谷歌翻译 以下为原文 What exactly do you mean by the: Be sure you check the signal integrity of having many such interfaces (drivers do not exceed simultaneous switching outputs limits - SSO). When an output buffer makes a transition, it draws current from the VCCO rail or sinks current to GND through the drive transistors. These transitions create momentary spikes of current. If too many high-drive outputs make transitions simultaneously, these current spikes can combine and cause a momentary disruption of the VCCO (called "droop") or the GND (called "ground bounce"). The net effect of these is that the outputs themselves may transition slower than expected, or even neighboring signals will show some disruption (even if they aren't transitioning). This is called "Simultaneous Switching Noise (SSN)" or the problems of "Simultaneously Switching Outputs (SSO)". Within a single bank of I/Os there is a maximum number of SSO that can be tolerated before we start seeing corruptions. This depends (very highly!) on I/O standard, drive strength and slew rates. It also depends on how "simultaneous" the signals are switching; even a skew of 1ns between two outputs switching can be enough to make them not be considered "simultaneous". By using the IOB flip-flops on the same clock, we are intentionally making the signals "as simultaneous as possible". When we are driving out clocks, we know that every clock transitions at twice a clock period. Thus SSN becomes a concern. But, again, it depends highly on the I/O standard - for example for LVCMOS33 with 16mA drive and fast transition, the maximum number of SSO is pretty small - well below the number of pins in the bank. However, at slow slew rate, you can pretty much have all pins switch simultaneously with no problems. Vivado (and ISE) have design rule checks for verifying SSO - in Vivado it is called SSN, in ISE it is called WASSO (Weighted Average SSO). Be sure to check these... Avrum |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 23:14 , Processed in 0.964485 second(s), Total 73, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
