我买了主板华硕H310M-E和CPU Intel G5400。
已安装的Windows 10.安装驱动程序之前hdmi端口正常工作。 安装驱动程序后不能正常工作hdmi端口,但VGA端口正常工作。 我从英特尔官方网站下载了所有版本的驱动程序。 没有版本可行。 (对不起,但我不懂英文) hdmi.png 43.7 K. DxDiag.txt.zip 14.3 K. SSUInfo.txt.zip 5.6 K. 以上来自于谷歌翻译 以下为原文 I bought motherboard ASUS H310M-E and CPU Intel G5400. Installed windows 10. Before installing driver hdmi port is work. After install driver not working hdmi port, but VGA port working. I downloaded all versions of the drivers from the official Intel site. No version works. (Sorry, but I do not know English)
5个回答
您好,boris_zervu。感谢您联系英特尔社区。尝试安装华硕提供的英特尔®高清显卡驱动程序:https://dlcdnets.asus.com/pub/ASUS/mb/07VGA/IntelVGA_24.20.100.6169DC_RS4PV_20180702.zip
?_ga = 2.71284816.155663006.1537202846-1486922127.1518557614请与我们分享结果.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, boris_zervu. Thank you for your contacting the Intel Community. Try installing the Intel® HD Graphics drivers provided by ASUS: https://dlcdnets.asus.com/pub/ASUS/mb/07VGA/IntelVGA_24.20.100.6169DC_RS4PV_20180702.zip?_ga=2.71284816.155663006.1537202846-1486922127.1518557614 Please share with us the results. Antony S. |
jerry1978 发表于 2018-11-2 09:24 谢谢。 我安装了驱动程序。 hdmi端口不起作用。 以上来自于谷歌翻译 以下为原文 Thank you. I installed the driver. The hdmi port does not work. |
您好,boris_zervu。感谢您的回复。我想知道在使用HDMI *(电缆类型,适配器等等)时,如何实现监控器和系统之间的连接。 另外,请让我知道您的显示器型号。那么,您是否尝试使用其他电视或显示器? 另外,请更新您的Windows 10 *。 您可以使用此Windows 10 *更新工具来执行此操作.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, boris_zervu. Thank you for your response. I would like to know how the connection between the monitor and your system is achieved when using HDMI* (type of cable, adapters, etc..). In addition, please let me know which is the model of your monitor. Then, have you tried using a different TV or monitor? Also, please update your Windows 10*. You can use this Windows 10* update tool in order to do so. Antony S. |
您好,boris_zervu。我想仔细检查您是否能够执行我附上上述帖子和结果的故障排除步骤.Antony S.Intel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello, boris_zervu. I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results. Antony S. Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 20:46 , Processed in 0.402961 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
