我在Intel Nuc NUC8i7HVK上安装了Windows 10 64位。
所有驱动程序均已从此站点下载用于英特尔®NUC套件NUC8i7HVK的下载并已安装。 NUC连接到Yamaha A3070接收器,然后连接到Sony TV Oled A1。 Belkin超高速4K HDMI电缆用于两种连接。 PowerDVD 18无法播放HDR视频,说我的电视无法播放HDR。 请帮我解决这个问题。 谢谢。 以上来自于谷歌翻译 以下为原文 I have Windows 10 64 bit installed on my Intel Nuc NUC8i7HVK. All drivers were downloaded from this site Downloads for Intel® NUC Kit NUC8i7HVK and installed. NUC is connected to Yamaha A3070 receiver and then to Sony TV Oled A1. Belkin Ultra High Speed 4K HDMI Cables used for both connections. PowerDVD 18 can't play HDR videos, saying that my TV can't play HDR. Please help me with this issue. Thanks. |
18个回答
如果直接将NUC连接到电视,它是否有效?
以上来自于谷歌翻译 以下为原文 Does it work if you direct connect the NUC to the TV? |
我试过了,但没有任何区别。 它说“你的电脑或显示设备不支持HDR。你想用SDR播放视频吗?” 我跑DxDiag。 随附的是报告。 谢谢。 DxDiag.txt.zip 17.2 K. 以上来自于谷歌翻译 以下为原文 I tried, but It made no difference. It says "You computer or display device does not support HDR. Do you want to play the video with SDR instead?” I run DxDiag. Attached is the report. Thanks.
嗨, 很抱歉给出这个答案,但NUC8I7HVK不支持蓝光UltraHD / HDR! 该限制内置于硬件,HDMI接口必须连接到英特尔图形电路,以此格式与蓝光UltraHD / HDR配合使用。 硬件使蓝光超高清工作的要求之一。 在NUC8I7HVK中,HDMI接口连接到AMD图形电路,参见NUC的技术规范。 英特尔哈迪斯峡谷:NUC8i7HVK:Windows 10:如何让它播放HDR 4K HEVC 10bit内容? 由于AMD Graphics不支持VP9编解码器,因此您无法在Youtube上播放4K / HDR。 最大值为1080P。 BR /比约恩 以上来自于谷歌翻译 以下为原文 Hi, Sorry to give this answer, but NUC8I7HVK is not supporting Blu-ray UltraHD /HDR! The limitation is built into the HW, HDMI interface must be connected to a Intel Graphic circuit to this format to work with Blu-ray UltraHD/HDR . One of the demanding requirements on the HW to get Blu-Ray Ultra HD to work. In NUC8I7HVK HDMI interface is connected to the AMD Graphics circuits., see Technical Specification for NUC. Intel Hades Canyon : NUC8i7HVK : Windows 10 : How can I get it to play back HDR 4K HEVC 10bit content? Neither you can play 4K/HDR on Youtube as the AMD Graphics does not support the VP9 Codec. The maximum is 1080P. BR/Björn |
ben233 发表于 2018-11-2 13:53 这真的令人失望。 不管怎么说,还是要谢谢你。 以上来自于谷歌翻译 以下为原文 It’s really disappointing. Thanks , anyway. |
ben233 发表于 2018-11-2 13:53 嗨, 我们可以使用eGPU来解决这个问题吗? 如果是的话,你推荐什么? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, Can we use an eGPU to solve this issue? If yes, what do you recommend? Thanks. |
你的硬件设置是什么? 什么是媒体,文件或磁盘? /比约恩 以上来自于谷歌翻译 以下为原文 What is your HW setup? What is the media on, a file or a disk? /Bjorn |
嗨, 我正在使用Intel Nuc NUC8i7HVK。 NUC连接到Yamaha A3070接收器,然后连接到Sony TV Oled A1。 Belkin超高速4K HDMI电缆用于两种连接。 媒体存档。 以上来自于谷歌翻译 以下为原文 Hi, I'm using Intel Nuc NUC8i7HVK. NUC is connected to Yamaha A3070 receiver and then to Sony TV Oled A1. Belkin Ultra High Speed 4K HDMI Cables used for both connections. The media is on file. |
不,据我所知,显示器必须连接到Intel Graphics 630或更高版本的主板。 如果您运行Cyberlink Ultra HD Advisor,您可以找到有关如何构建支持UltraHD Blu-Ray HDR的PC的信息。 BR /比约恩 以上来自于谷歌翻译 以下为原文 No, as I understand the display must be connected to a motherboard with Intel Graphics 630 or better. If you run Cyberlink Ultra HD Advisor you can find information how to build a PC that supports UltraHD Blu-Ray HDR. BR/Björn |
ben233 发表于 2018-11-2 14:52 嗨, 谢谢你的帮助。 顺便问一下,有没有其他英特尔nuc可以做到这一点? 以上来自于谷歌翻译 以下为原文 Hi, Thanks for your help. Btw, is there any other Intel nuc that can do this? |
嗨, NUC8I3BE / NUC8I5BE / NUC8I7BE似乎符合纸上要求。 https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/NUC8i3BE_NUC8i5BE_NUC8i7BE_TechProdSpec.pdf 唯一缺少的功能是BIOS中的SGX支持。 但我想它就在那里? 您最好与英特尔验证它是否支持所有要求。 BR /比约恩 以上来自于谷歌翻译 以下为原文 Hi, NUC8I3BE/NUC8I5BE/NUC8I7BE seems to meet the requirement on paper. https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/NUC8i3BE_NUC8i5BE_NUC8i7BE_TechProdSpec.pdf The only missing function is SGX support in BIOS. But I guess it's there? You better verify with Intel that it support all requirements. BR/Björn |
ben233 发表于 2018-11-2 15:20 大家好,感谢您提供的信息。关于英特尔®NUC的英特尔®软件保护扩展,需要: - 如果在BIOS中启用了SGX安全性 - 播放UHD蓝光内容。英特尔®软件保护扩展(英特尔®Intel®) SGX)用于英特尔®NUC(NUC8I3BE / NUC8I5BE / NUC8I7BE)我希望您对此信息有所帮助.Wanner G. 以上来自于谷歌翻译 以下为原文 Hello all, Thank you for the information provided. Regarding the Intel® Software Guard Extensions for Intel® NUC, it is required: -If SGX security is enabled in BIOS. -To play UHD Bluray content. Intel® Software Guard Extensions (Intel® SGX) for Intel® NUC (NUC8I3BE / NUC8I5BE / NUC8I7BE) I hope you find this information helpful. Wanner G. |
jerry1978 发表于 2018-11-2 15:36 嗨, 我在Bios中启用了SGX,然后尝试安装英特尔®软件保护扩展,但失败了。 它说 “检测到致命的安装阻止问题。 AESM已经在这个平台上安装了AESM。 安装将取消“。 以上来自于谷歌翻译 以下为原文 Hi, I enabled SGX in Bios, and then tried to install Intel® Software Guard Extensions, but failed. It says "Fatal installation blocking issues are detected. AESM has already installed by INF on this platform. Install will cancel". |
您使用哪种NUC? /比约恩 以上来自于谷歌翻译 以下为原文 Which NUC are you using? /Bjorn |
这是NUC8I7HVK 以上来自于谷歌翻译 以下为原文 It’s NUC8I7HVK |
None 以上来自于谷歌翻译 以下为原文 Hi, I have manage to activate SGX on my NUC8I7HVK, but it does not help in getting UHD Blu-ray support as Advanced Protected Audio/Video Path is not support in Vega Graphic. This HW platform will never support UHD Blu-ray. If you want anyway SGX on your system I think the Intel people should be able to help you. By the way, which country are you from? BR/Bjorn |
None 以上来自于谷歌翻译 以下为原文 Hi, I found a good document on the subject HDR on Intel Graphics https://www.intel.com/content/dam/support/us/en/documents/graphics/HDR_Intel_Graphics_TechWhitePaper.pdf The table at the end of the document gives a good overview of the requirements depending on the HDR source. BR/Björn |
None 以上来自于谷歌翻译 以下为原文 Hi, Thanks very much for your help. I’m from Vietnam |
None 以上来自于谷歌翻译 以下为原文 I have found some more information about this subject on Intel Site. A link to a report from about Compatibility information NUC8I7BE. It show that it must support UHD Blu-ray as there is one UHD 4K Drive listed http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel®%20NUC&productType=Kits&productName=Intel®%20NUC%20Kit%20NUC8i7BEH Tips for playing 4K or HDR material on Intel NUC https://www.intel.com/content/www/us/en/support/articles/000029357/mini-pcs.html?wapkw=nuc8i7be BR/Björn |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 10:20 , Processed in 0.863641 second(s), Total 89, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
