嗨,我想同步一个工作区(或实际上是几个),以便在多台计算机上工作。
例如,我在白天开始使用我的桌面,但是想在晚上继续使用我的笔记本电脑。 在2011年之前的版本中(迁移到OA数据库),这非常简单。 我可以将项目从computer1同步到例如 云服务器,然后将云版本同步到计算机2。 任何建议都非常感谢。 我还要补充一点,我使用的是至少一个,有时是几个设计套件。 最好的问候,马蒂亚斯 以上来自于谷歌翻译 以下为原文 Hi, I'm want to sync a workspace (or actually several) in order to work on several computers. For example I start out with my desktop during the day but want to continue on my laptop in the evening. In the releases before 2011 (with the migration to OA-database) this was quite straightforward. I could just sync the project from computer1 to e.g. a cloud server and then sync the cloud-version to computer2. Any suggestions are highly appreciated. I should also add that I'm using at least one, sometimes several, design kits. Best regards, Mattias |
2个回答
嗨Mattias,我正在使用ADS版本控制系统(Perforce),还需要了解OA数据库在文件级别的真正作用。
从本质上讲,您的方法应该有效。 每个单元格都驻留在一个文件夹中,每个视图中都有一个单独的文件夹。 如果打开了原理图/布局视图,则会创建一个* .oa.cdslck文件,该文件将单元格视图标记为只读给其他用户。 如果您复制文件,请确保关闭所有内容,否则您需要先删除* .oa.cdslck文件,然后才能保存对该单元格视图的更改。 根据我的经验,您可以通过压缩/删除相应的文件夹内容来复制/删除单元格和单元格视图。 当我从技术B中的现有设计中获得技术A的设计时,我就这样做了。如果缺少所需的PDK或技术,您将看到“灰色”布局图(不存在图层)或其他迹象表明存在损坏 链接。 添加一个使该定义再次可用的PDK后,单元格再次正常工作。 祝你好运! 沃尔克 以上来自于谷歌翻译 以下为原文 Hi Mattias, I am using ADS with a version control system (Perforce) and also needed to understand what that OA database really does at file level. Essentially, your approach should work. Each cell resides in a folder, and therein each view has a separate folder. If a schematic/layout view is open, this creates an *.oa.cdslck file that marks the cell view as read only for other users. If you copy around files, make sure you have everything closed, or otherwise you will need to delete the *.oa.cdslck files before you can save changes to that cell view. From my experience, you can copy/remove cells and cell views by coyping/removing the corresponding folder content. I did that when deriving designs for technology A from an existing design in technology B. If the required PDK or technology is missing, you will see "gray" layout drawing (where drawing layers don't exist) or other indication that there's a broken link. Once you add a PDK that makes that definition available again, the cells work fine again. Good luck! Volker |
lmksa 发表于 2018-11-1 08:14 谢谢。 效果很好。 以上来自于谷歌翻译 以下为原文 Thanks. Works excellent. |
只有小组成员才能发言,加入小组>>
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 05:19 , Processed in 0.993399 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
