我刚刚买了一个Hades Canyon NUC8i7HNK1,我希望它能完美地运行游戏。
然而,当我运行任何游戏时,CPU和GPU飙升至100%,即使在最低设置下也无法播放游戏。 我甚至无法运行Warhammer Vermintide 2,它可以通过该设备免费下载。 有关为什么会发生这种情况的任何想法? 以上来自于谷歌翻译 以下为原文 I just recently bought a Hades Canyon NUC8i7HNK1 which I expected to run games flawlessly. However when I run any game, the CPU and GPU spike to 100%, making the game unplayable, even on the lowest settings. I can't even run Warhammer Vermintide 2, which was a free download with the device. Any ideas as to why this is happening? |
8个回答
除了游戏之外你还安装了其他任何东西吗?
如果是这样,什么? 你有什么反病毒? 文件 以上来自于谷歌翻译 以下为原文 Did you install anything else besides the game(s)? If so, what? What anti-virus do you have? Doc |
我在Windows NUC上安装了Windows 10企业版。 之后,我为家庭实验室安装了一些Windows功能(hyper-v,telnet,snmp),然后我安装的唯一应用程序是Chrome,Steam和一些游戏。 我没有安装任何防病毒软件。 以上来自于谷歌翻译 以下为原文 I installed Windows 10 Enterprise onto the NUC. After that, I installed some windows features (hyper-v, telnet, snmp) for home-lab purposes, then the only applications I installed was Chrome, Steam, and a couple games to play. I have not installed any antivirus. |
脑洞大赛11 发表于 2018-10-31 09:35 另一个W10企业用户,嗯? 打开这些窗口功能应该不是问题。 Chrome(以及Edge,IE等)可能会占用大量内存和一些处理器时间。 我不知道Steam,但是你在Steam上存下了很多游戏和设置吗? 不过,这不应该导致你看到的问题。 除此之外,你听起来合情合理。 下载,运行并附加此实用程序的结果:下载适用于Windows *的英特尔®系统支持实用程序 也许英特尔支持工程师之一有一些建议。 文件 以上来自于谷歌翻译 以下为原文 Another W10 Enterprise user, eh? Turning on those windows features should not be an issue. Chrome (as well as Edge, IE, etc) can consume a lot of memory and some processor time. I do not know about Steam, but did you have a lot of games and settings stored on Steam that it is downloading? Still, that should not cause the problems you are seeing. Other than that, what you have sounds reasonable. Download, run, and attach the results of this utility: Download Intel® System Support Utility for Windows* Perhaps one of the Intel support engineers has some suggestions. Doc |
听起来你很快就会受到热量限制。
NUC8i7HNK中的CPU是一个65瓦的TDP封装,所以我认为与NUC8i7HVK(100瓦TDP封装)中的CPU相比,保持冷却会更容易。 冷却风扇是否能够快速升温以满足热量需求,还是保持相对安静? 我只是想知道BIOS中的风扇冷却配置文件是否设置错误.... 我怀疑这种热量限制不是软件问题(虽然我当然可能是错的)。 假设这是一个硬件问题,我可以想一想它可能发生的原因: 1.冷却风扇运转不正常和/或旋转速度不够快。 由于多种原因,冷却风扇可能出现故障,包括不能足够快地旋转,或者没有足够积极地对温度变化做出反应。 风扇冷却的BIOS设置可能未正确设置或已损坏。 可能的解决方案是将BIOS更新到最新版本(如果它尚未在最新版本中)并重新启动,然后加载该BIOS版本的默认设置。 检查风扇冷却配置文件是否设置为“平衡”。 2.核心CPU电压有点太高了。 这是另一个BIOS问题,其修复方式与#1相同。 我没有我的NUC在我面前,所以我不能告诉你Vcore应该是什么,但如果你想让我看一看,我今晚可以找到你的信息。 3. CPU和散热器之间的热界面材料不良。 CPU和散热器之间的热界面材料可能很难应用,并且无法正常工作。 解决这个问题的唯一方法就是将装置拆开,拆下散热器,清除所有旧的TIM,然后重新使用更好的东西,比如热毛茸茸的kryonaut甚至导航器。 不幸的是,这是一个保修无效的操作,所以只有你真的想要这样做。 4.需要更换的缺陷单元。 这个很不言自明...... - 罗伯特· 以上来自于谷歌翻译 以下为原文 It sounds like you're hitting thermal throttling very quickly. The CPU in the NUC8i7HNK is a 65 watt TDP package, so I would think that it would be easier to keep cool as compared to the CPU in the NUC8i7HVK, which is a 100 watt TDP package. Are the cooling fans ramping up quickly to meet the thermal demands, or are they staying relatively quiet? I'm just wondering if the fan cooling profile is set incorrectly in the BIOS.... I suspect that this thermal throttling is not a software issue (though I could certainly be wrong). Assuming it's a hardware issue, I can think of a few reasons why it might be happening: 1. Cooling fans are not working correctly and/or spinning fast enough. The cooling fans could be at fault for a number of reasons, including simply not spinning fast enough, or not reacting to temperature changes aggressively enough. It's possible the BIOS setting for fan cooling is not set correctly or is corrupted. Possible solution is to update BIOS to latest version (if it's not already at the latest version) and reboot, and then load the default settings for that BIOS version. Check to see if the fan cooling profile is set to "balanced". 2. Core CPU voltage is somehow too high. This is another BIOS issue and is fixed the same way as #1. I don't have my NUC in front of me, so I can't tell you what Vcore should be, but if you want me to take a look I can find that info for you tonight. 3. Bad thermal interface material between CPU and heatsink. It's possible that the thermal interface material between the CPU and heatsink has been poorly applied and isn't doing it's job correctly. The only way to fix this is take the unit apart, remove the heatsink, clean out all the old TIM, and reapply using something better like Thermal grizzly kryonaut or even conductonaut. Unfortunately, this is a warranty-voiding operation, so only do this if you really want to. 4. Defective unit that just needs to be replaced. This one's pretty self-explanatory... -Robert |
JasonXiong 发表于 2018-10-31 10:00 我更新了BIOS并确认风扇设置设置为Balanced,BIOS更新没有让它变得更好。 我还运行了Diagnostic Utility并附上了该文件,并向英特尔提交了一张票。 nuc.txt.zip 6.3 K. 以上来自于谷歌翻译 以下为原文 I updated the BIOS and confirmed the fan setting is set to Balanced, the BIOS update did not make it any better. I also ran the Diagnostic Utility and attached the file, as well as submitted a ticket to Intel.
脑洞大赛11 发表于 2018-10-31 10:12 我发现了一些基于您发布的Intel diag实用程序的内容: 1.您正在设备上运行BIOS 37。 最新版本是49:下载BIOS更新[HNKBLi70.86A] 2.您尚未安装AMD Radeon RX Vega M驱动程序。 视频驱动程序仍列为“Microsoft Basic Display Adapter”。 下载用于Windows®Server2016的Radeon™RX Vega M图形驱动程序,用于英特尔®NUC套件NUC8i7HNK,NUC8i7HVK 3.英特尔高清显卡的驱动程序版本不是最新版本:为英特尔®NUC套件NUC8i7HNK下载用于Windows®1064位的英特尔®高清显卡驱动程序,NUC8i7HVK 更新所有这些内容,特别是#2,可能会非常有用。 - 罗伯特· 以上来自于谷歌翻译 以下为原文 I noticed a couple of things based on the Intel diag utility that you posted: 1. You're running BIOS 37 on the device. The latest version is 49: Download BIOS Update [HNKBLi70.86A] 2. You have not installed the AMD Radeon RX Vega M Driver. The video driver is still listed as "Microsoft Basic Display Adapter". Download Radeon™ RX Vega M Graphics Driver for Windows® Server 2016 for the Intel® NUC Kit NUC8i7HNK, NUC8i7HVK 3. The driver version for Intel HD graphics is not the latest version: Download Intel® HD Graphics Driver for Windows® 10 64-bit for the Intel® NUC Kit NUC8i7HNK, NUC8i7HVK Updating all of those things, especially #2, could be very helpful. -Robert |
JasonXiong 发表于 2018-10-31 10:20 罗伯特, 这些直截了当的答案使这个社区成为一个很棒的地方。 以上来自于谷歌翻译 以下为原文 Robert, These straight-forward answers are what make this community an awesome place to hang out. |
然而,当我运行任何游戏时,CPU和GPU飙升至100%,即使在最低设置下也无法播放游戏。 我甚至无法运行Warhammer Vermintide 2,它可以通过该设备免费下载。 有关为什么会发生这种情况的任何想法? 嗨,我看到你可能有一些运气我知道你有我的相同单位将运行任何你可以扔它的游戏正常在4K 30FPS +我运行以下游戏没有问题 Forza Horizon 3和4,Forza Motorsport 6 Apex和7以及Gears of War 4,Recore和其他几个我将为你们链接一个GPU驱动程序,这些人在这里帮助了我。 我发现NUC非常适合游戏,并且发现如果它有点热,那么我将使用游戏全局设置的GPU设置将帧速率锁定到大约40FPS您还可以正常选择每个游戏的设置。 如果我希望游戏以更高的帧速率运行,我将使用高或超设置将其降至1080p。 但是,一旦安装了正确的驱动程序,我列出的每个游戏都将至少运行4K 30FPS或Ultra设置。 有关详细信息,请参阅GPU驱动程序错误游戏。 感谢rhildinger的链接 下载Radeon™RX Vega M图形 希望你有几个小时的无忧游戏。 以上来自于谷歌翻译 以下为原文 I just recently bought a Hades Canyon NUC8i7HNK1 which I expected to run games flawlessly. However when I run any game, the CPU and GPU spike to 100%, making the game unplayable, even on the lowest settings. I can't even run Warhammer Vermintide 2, which was a free download with the device. Any ideas as to why this is happening?Hi I see you may have had some luck I do know that the Unit you have Same as Mine will run any game you can throw at it Normal in 4K 30FPS+ I run the Following games without a Problem Forza Horizon 3 and 4, Forza Motorsport 6 Apex and 7 as well as Gears of War 4, Recore and several others I will link a GPU Driver for you that the guys here helped me with the other day. I find the NUC great for gaming and have found that if it gets a tad Hot then I just will lock the Frame rate to about 40FPS using the GPU settings for Games Global Settings You can also select the setting for each game normally. And if I want the games to run at a Higher frame rate I will just drop it to 1080p with either high or Ultra settings. But every game I listed will run at least 4K 30FPS high or Ultra settings once you have the correct Driver installed. See post GPU Driver Error Gaming For more details. Thanks to rhildinger for the link Download Radeon™ RX Vega M Graphics Hoping you have many hours of hassle free gaming. |
只有小组成员才能发言,加入小组>>
245浏览 0评论
GMT+8, 2024-4-19 07:35 , Processed in 0.648502 second(s), Total 80, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
