我一直在使用ST Visual Developer 6个月没有这个问题。我正在处理我正在处理的项目时出现问题,并认为重新安装该工具可能会有所帮助。一旦我卸载了该工具并安装了最新版本,程序将在几分钟后崩溃,或者在启动编程工具时立即崩溃。它给了我错误信息'Out of Memory'
对这个问题的任何决议? 以上来自于谷歌翻译 以下为原文 I have been using ST Visual Developer for 6 months without this issue. I was having problems with a project I am working on and thought that re-installing the tool might help. Once I un-installed the tool and installed the latest version the program will either crash after a few minutes, or crash immediately when launching the programming tool. It gives me the error message 'Out of Memory' Any resolutions to this issue? |
9个回答
你好,
“内存不足”错误让人想到日益增长的.wed和.wdb文件的问题,在这种情况下应该删除(另请参见STVD发行说明的第3.3章)。使用STVD-4.3.12确认编程工具崩溃;它可能是通过使用此处附带的先前版本(STVP-3.4.0)的stvp / tools.cnf文件来设计的(如果以后想要使用STVP-3.4.1,请保留原始文件的副本,而无需重新安装)。真正的修复将在稍后提供。 如果崩溃仍然存在,请加入文件stvd / stvd_pm.log以便于调查。 以上来自于谷歌翻译 以下为原文 Hello, The 'out of memory' error makes think about issue with ever growing .wed and .wdb files, which should be deleted in this case (see also chapter 3.3 of STVD release notes). The crash with the programming tool is confirmed with STVD-4.3.12; it might be workarounded by using stvp/tools.cnf file from previous version (STVP-3.4.0) attached here (keep a copy of the original file if wanting to use STVP-3.4.1 later, without having to reinstall). The real fix will be provided later. If the crash persists, please join the file stvd/stvd_pm.log in order to allow easier investigations. |
我也在使用STVD-4.3.12。替换stvp目录中的tools.cnf文件更正了我在尝试使用STVD程序员时遇到的崩溃。感谢您提供解决方法。
以上来自于谷歌翻译 以下为原文 I am also using STVD-4.3.12. Replacing the tools.cnf file in the stvp directory corrected the crashes that I was experiencing when trying to use the programmer from STVD. Thank you for supplying the workaround. |
文件tool.cnf在我的安装中不存在,即使它不起作用,缺陷仍然存在
以上来自于谷歌翻译 以下为原文 the file tool.cnf does not exist in my installation, even if it does not work, the defect remains |
它在STVP目录中,而不是STVD!
您必须拥有此文件... STVP将无法在独立模式下运行。 RGDS, 洛朗 以上来自于谷歌翻译 以下为原文 It's in STVP directory, not STVD !!! You must have this file...STVP wouldn't working in standalone mode. Rgds, Laurent |
我无法下载附件,有人可以再次发布吗?
以上来自于谷歌翻译 以下为原文 I was not able to download the attached file, could someone post it again? |
该文件不可用。你可以重新贴上吗?
以上来自于谷歌翻译 以下为原文 The file is not available. Can you re-attach please? |
使用真正的ide,你不必担心这个问题。
以上来自于谷歌翻译 以下为原文 Use a real ide and you don't to worry about that problem. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1392 浏览 1 评论
2046 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2798 浏览 6 评论
5169 浏览 21 评论
351浏览 4评论
486浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
537浏览 3评论
466浏览 3评论
GMT+8, 2024-4-18 05:14 , Processed in 0.767331 second(s), Total 82, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
